shapefile name lenght
4030
11-16-2012 03:08 PM
FranceLabrecque
Is there a maximum length for the shapefile name? I read somewhere it is 10 characters.
Is it true?
curtvprice
Yes, for this and other details of shapefile limitations, see this article in the help:
Geoprocessing considerations for shapefile output
Luke_Pinner
MVP Regular Contributor
Field names cannot be longer than 10 characters. No limitation for the file name that I'm aware of.
curtvprice
Luke you're absolutely right. I posted a little quick there. The 10-char limitation is indeed on the field names. In general, you should always at least start with a letter and stick to alphanumeric characters plus "_" for folder paths and names in ArcGIS.
