SQL statements
3640
12
11-16-2012 04:05 AM
Corbinde_Bruin
Hi all,
I'm new to SQL statements and especially within ArcGIS. I'm programming an addin against a file geodatabase in in Desktop 10.1 and I'm getting this error:
An invalid SQL statement was used.
[SELECT FeatureClassAlias FROM tblFeatureClasses WHERE IsSearchable = 'Y' ORDER BY SortSequence]
It works if I take out the ORDER BY SortSequence part, but it obviously doesn't sort at all. I've looked at all the ESRI references on SQL with File geodatabases and can't see my error. It says field names may be delimited by quotes, but that hasn't helped. It also says that ORDER BY won't work if I'm searching in all fields with SELECT *, but that shouldn't be my problem.
[SELECT "FeatureClassAlias" FROM tblFeatureClasses WHERE "IsSearchable" = 'Y' ORDER BY "SortSequence"]
I'd greatly appreciate help with this issue from someone with SQL experience. I'll also post the code if you think it will help.
Thank you,
cdebruin
  Public Sub LoadTblToCbx(inputTable As ITable, inputFieldName As String, cbxInput As System.Windows.Forms.ComboBox)                  ' Create the query filter.         Dim queryFilter As IQueryFilter2 = New QueryFilter          ' Select the fields to be returned         queryFilter.SubFields = inputFieldName          ' Set the filter to return only searchable         queryFilter.WhereClause = """IsSearchable"" = 'Y'"          ' Use the PostfixClause to sort ascending         Dim queryFilterDef As IQueryFilterDefinition2 = CType(queryFilter, IQueryFilterDefinition2)         queryFilterDef.PostfixClause = "ORDER BY ""SortSequence"""          ' Output the returned feature class name.         Dim fieldIndex As Integer = inputTable.FindField(inputFieldName)         Dim cursor As ICursor = inputTable.Search(queryFilter, True)         Dim row As IRow = cursor.NextRow()         While Not row Is Nothing             Dim field As String = Convert.ToString(row.Value(fieldIndex))             cbxInput.Items.Add(field)             row = cursor.NextRow()         End While          Marshal.FinalReleaseComObject(cursor)      End Sub
LanceShipman
ORDER BY is supported by File Geodatabase at ArcGIS 10.0. You must include the sort field(s) in the field list.
Something like:
' Select the fields to be returned queryFilter.SubFields = inputFieldName & ", SortSequence"  ' Set the filter to return only searchable queryFilter.WhereClause = """IsSearchable"" = 'Y'"  ' Use the PostfixClause to sort ascending  Dim queryFilterDef As IQueryFilterDefinition2 = CType(queryFilter, IQueryFilterDefinition2)  queryFilterDef.PostfixClause = "ORDER BY SortSequence"
MichaelVolz
Esteemed Contributor
Try this for additional information:
http://resources.esri.com/help/9.3/ArcGISEngine/arcobjects/esriGeoDatabase/IQueryFilterDefinition.Po...
[Visual Basic 6.0]'this is an example of using the PostfixClause property to append a Order By clause to the query
Dim pQueryFilter As IQueryFilterSet pQueryFilter = New QueryFilterpQueryFilter.SubFields = "FULLNAME"pQueryFilter.WhereClause = "OBJECTID > 10"
Dim pQueryFilterDefinition As IQueryFilterDefinitionSet pQueryFilterDefinition = pQueryFilterpQueryFilterDefinition.PostFixClause = "ORDER BY FULLNAME"
Dim pFeatureCursor As IFeatureCursorSet pFeatureCursor = pFeatureClass.Search(pQueryFilter, True)
Dim codeix As Longcodeix = pFeatureCursor.FindField("FULLNAME")
Dim pFeature As IFeatureSet pFeature = pFeatureCursor.NextFeature
While Not pFeature Is Nothing    MsgBox pFeature.Value(codeix)    Set pFeature = pFeatureCursor.NextFeatureWend
Another forum example:
Set queryFilter = new QueryFilter
queryFilter.WhereClause = "theField = 'abc'"
Set queryFilterDef = queryFilter
queryFilterDef.PostfixClause = "ORDER BY sortField"
Corbinde_Bruin
Hmm,
No luck. I tried that syntax and I'd already referenced that VB6 example.
Thanks you Mike
AndrewMay
Do filegeodatabase support the ORDER BY function? They didn't used to in ArcGIS 9 - not sure whether they do or not in 10.
From http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//003n00000032000000:
  • File geodatabases do not support all the features and functions available for personal geodatabases. At ArcGIS 9.2, the most commonly used functions not supported by file geodatabases include DISTINCT, GROUP BY, and ORDER BY, and the set functions AVG, COUNT, MIN, MAX, and SUM are not supported outside subqueries. Support for some of these is likely to be added in future releases.
Corbinde_Bruin
That's a question I was hoping someone else could answer, haha. I see it's supported in subqueries. Can I somehow use subqueries as a workaround. I don't really understand the syntax for subqueries.
Thank you for you reply Andrew
MichaelVolz
I think this link answers your question that this is not currently possible:
http://support.esri.com/en/bugs/nimbus/TklNMDY0NDcy
Is there any chance you could call this layer from an SDE geodatabase where ORDER BY is supported?
You might try a personal geodatabase as it might also be supported there, but you would need to test that out.
Corbinde_Bruin
We will actually be moving to an SDE environment for our current project, so I'm glad to know that it works there.
I wanted to know if it worked in File geodatabases for other/future purposes.
Thanks Mike
LanceShipman
Something like:
Corbinde_Bruin
Thank you for responding Lance,
I'm not sure what you mean by field list. Perhaps you could take a quick look at my code up top and see where I went wrong? Or point me towards an example where this field list is used/documented/explained?
-cdebruin
LanceShipman
See the code fragment that I posted. SubField is the field list.
Lance
