Using a Drawing Toolbar
1025
11-07-2012 12:33 PM
melissaGomez
I hoping someone can lead me the right direction here? I am working on a map trying to insert a drawing toolbar and so far I have only been able to get the drawing toolbar up, but not where I can actual edit with it. I have attached the script below, but wondering if I am inserting the Function create toolbar in the correct area? If not, could you please let me know how and where it should be located, so I can get this option working on my map? Please help.. thanks..
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
      <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title> World Street Map</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css" />
    <style>
      html,body,#map,.map.container{
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script type="text/javascript">var djConfig = {parseOnLoad: true};</script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2"></script>
      dojo.require("esri.map");
      var map;
      function init() {
        var initExtent = new esri.geometry.Extent({"xmin":1951567,"ymin":13596243,"xmax":2336550,"ymax":13862302,"spatialReference":{"wkid":2278}});
        map = new esri.Map("map",{extent:initExtent});
//  var initExtent = new esri.geometry.Extent({"xmin":-10997600,"ymin":3416600,"xmax":-10933500,"ymax":3444000,"spatialReference":{"wkid":102100}});
    //    map = new esri.Map("map",{extent:initExtent});
       //Add the world street map layer to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://wdgissom01/ArcGIS/rest/services/CoreSA/MapServer");
        map.addLayer(basemap);
// var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
     //   map.addLayer(basemap);
        dojo.connect(map, 'onLoad', function(theMap) {
          //resize the map when the browser resizes
          dojo.connect(window, 'resize', map,map.resize);
// here is where I've inserted my options in order to edit with the drawing toolbar, which is in question.
      function createToolbar(map) {
        toolbar = new esri.toolbars.Draw(map);
        dojo.connect(toolbar, "onDrawEnd", addToMap);
      function addToMap(geometry) {
       switch (geometry.type) {
          case "point":
            var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 1), new dojo.Color([0,255,0,0.25]));
            break;
          case "polyline":
            var symbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([255,0,0]), 1);
            break;
          case "polygon":
            var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25]));
            break;
          case "extent":
            break;
          case "multipoint":
            var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_DIAMOND, 20, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0,0,0]), 1), new dojo.Color([255,255,0,0.5]));
            break;
        var graphic = new esri.Graphic(geometry, symbol);
        map.graphics.add(graphic);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
  Draw :
    <button dojoType="dijit.form.Button" onClick="toolbar.activate(esri.toolbars.Draw.POINT);map.hideZoomSlider();">Point</button>
    <button dojoType="dijit.form.Button" onClick="toolbar.activate(esri.toolbars.Draw.MULTI_POINT);map.hideZoomSlider();">Multipoint</button>
    <button dojoType="dijit.form.Button" onClick="toolbar.activate(esri.toolbars.Draw.LINE);map.hideZoomSlider();">Line</button>
    <button dojoType="dijit.form.Button" onClick="toolbar.activate(esri.toolbars.Draw.POLYLINE);map.hideZoomSlider();">Polyline</button>
    <button dojoType="dijit.form.Button" onClick="toolbar.activate(esri.toolbars.Draw.POLYGON);map.hideZoomSlider();">Polygon</button>
    <button dojoType="dijit.form.Button" onClick="toolbar.activate(esri.toolbars.Draw.FREEHAND_POLYLINE);map.hideZoomSlider();">Freehand Polyline</button>
    <button dojoType="dijit.form.Button" onClick="toolbar.activate(esri.toolbars.Draw.FREEHAND_POLYGON);map.hideZoomSlider();">Freehand Polygon</button>
    <button dojoType="dijit.form.Button" onClick="toolbar.deactivate();map.showZoomSlider();">Deactivate</button>
    <div id="map" style="width:900px; height:600px; border:1px solid #000;"></div>
    <div id="map">
    </div>
  </body>
</html>
melissaGomez
Thanks all for viewing, but I ended up figuring out the solution.
Melissa
melissaGomez
Melissa
