IdentifyTask Error
2213
7
11-01-2012 12:48 PM
AndyStewart1
I am doing some work for a client using 9.3 and the IdentifyTask is acting strange. I get the following error: "Could not complete the operation due to error c00ce56e". Any ideas what I could be doing wrong? Is there something in the service settings that could be causing this? My code is below.
dojo.connect(map, "onClick", SimpleIdentifyTask);  function SimpleIdentifyTask(evt) {  var identifyTask = new esri.tasks.IdentifyTask("http://[hidden]/ArcGIS/rest/services/myMap/MapServer");  var identifyParams = new esri.tasks.IdentifyParameters();  identifyParams.tolerance = 2;  identifyParams.returnGeometry = true;   identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;  identifyParams.layerIds = [5,7];  identifyParams.geometry = evt.mapPoint;  identifyParams.mapExtent = map.extent;  identifyParams.spatialReference = map.spatialReference;  identifyTask.execute(identifyParams, function(idResults) { alert(idResults.length); }, function(err){alert(err.message);}); }
AndyStewart1
I figured out the problem. The proxy.jsp file does not work in older versions of Java. Specifically it doesn't like the ".contains" method. I switched out this line of code:
if(reqUrl.toLowerCase().contains(stokens[0].toLowerCase())) {
with this one
if(reqUrl.toLowerCase().indexOf(stokens[0].toLowerCase())>=0) {
and replace
for(String surl : serverUrls) {
with this
for(int i = 0; i<serverUrls.length; i++) {  String surl = serverUrls;
and it worked.
AndyStewart1
Our client upgraded to 10.1 and I am still getting the same error. Has anyone seen this before?
JohnGravois
what happens when you try to make a similar identify request directly from the rest services page?
AndyStewart1
I have narrowed it down to the proxy.jsp file not compiling correctly for some reason. The IdentifyTask goes through the proxy because the client uses a well-known text for their Spatial Reference, so it forces it through the proxy. I have downloaded the proxy directly from the arcgis.com website and the only thing I changed was the serverUrls variable. Still troubleshooting.
AndyStewart1
with this one
and replace
with this
and it worked.
JohnGravois
nice troubleshooting!  thanks for taking the time to share the exact fix for the problem.
in working with another customer today i believe we pinpointed a similar problem when Oracle WebLogic was used for hosting.  in version 10.3.3.0 of WebLogic, our JSP proxy worked out of the box, but it was necessary to make a few changes to get things up and running in version 8.1.4 because of the underlying version of Java in use.
AndyStewart1
That was us.
JohnGravois
hahaha.  i had my suspicions. 😉
