Error while loading multiple Dojo
1310
11-01-2012 08:42 AM
MoizBhukhiya
Hello!
I have an application running Dojo 1.7.1 and I am trying to add ESRI maps to it.
When I load v3.2 I keep getting these errors http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2:
TypeError: _14c.syncLoadNls is not a function
TypeError: i18n._preloadLocalizations is not a function
When I load version 1.6 or 2.0 it works fine. http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.6 (2.0)
What version of Dojo is used in ESRI 3.2? I guess its 1.7.3..
derekswingley1
<snip>... I just provided the path to esri modules in dojoConfig (packages=>location) and it seems to work fine. Is it in any case unsafe?
We don't test that but if it works for you...go for it.
derekswingley1
Yes, 3.2 uses Dojo 1.7.3. Rather than loading your separate copy of 1.7.1, can you use the 1.7.3 that's bundled with our API?
MoizBhukhiya
Thank you for your response swingley!
Currently I have dependency on 1.7.1.
Instead of loading dojo.js and jsapi.js, I just provided the path to esri modules in dojoConfig (packages=>location) and it seems to work fine. Is it in any case unsafe?
Thanks!!
derekswingley1
