Building texture
1242
10-30-2012 12:45 AM
Thu_GiangDang
I am trying to add random texture to the my buildings by using the code provided in the tutorial with minor changes. When I assign the rule to the building polygons and generate, the result was mixed: some buildings has texture applied to them, while other remain blank (white). In some case, only one or two sides of the building have texture, but the rest is blank. Please view screenshot as below:
And here's my rule file code:
const randomFacadeTexture = fileRandom("data/facade_textures/f*.tif") attr floorheight = rand(4,5)  actualFloorHeight =   case scope.sy >= floorheight : scope.sy/rint(scope.sy/floorheight)  else : scope.sy   actualTileWidth =   case scope.sx >= 2 : scope.sx/rint(scope.sx/4)  else : scope.sx  Lot -->  extrude(HEIGHT)  comp(f){front: Facade | side: Facade | top: Roof }  Building.  Facade -->  setupProjection(0, scope.xy, 8*actualTileWidth, 8* actualFloorHeight)  texture(randomFacadeTexture)  projectUV(0)
My building layer has 9000+ polygon. I wonder if that is a problem if the number of polygon/faces is too large.
Thank you for your time!
MatthiasBuehler1
Hi !
In the Lot rule, you have a copy of the shape defined with 'Building'.
Try deleting this line and check how this works out.
Let me know..
M.
MatthiasBuehler1
Hi !
Let me know..
M.
Thu_GiangDang
Thank you!! It works like magic! What is the reason behind this?
MatthiasBuehler1
Haha, no magic at all.
Lot -->
    A.
copies the shape of Lot to A.
Lot -->
    B.
copies to B, logically.
If you write
Lot -->
    A.
    B.
the shape coming from Lot is copied to A. and duplicated to B. So there's 2 copies of on top of each other.
test this with
Lot -->
    alignScopeToAxes(y)
    A.
    t(0,10,0)
    B.
Please watch all Tutorial videos, find them here:
http://forums.arcgis.com/threads/64843-CityEngine-Collection-RESOURCES-FAQ-HELP
Especially, the CGA basics are explained, see tuto 6.
Matt
