Unable to delete feature service
4264
6
10-24-2012 10:50 AM
JaredCollier
I tried to overwrite a feature service from Arcmap to AGOL.  It said completed successfully however I have been unable to access the service in the AGOL Map it was in.  Furthermore I am unable to delete it from my list to completely recreate.  Any suggestions?
I am unable to access the service on both new AGOL maps and Arcgis Explorer online, but I can add it to Arcmap as a layer?
Recreated the feature service with another name, recreated all of my settings, popup configurations etc in a new web map.  Deleted the web map using the non responsive feature service thinking that this was hanging the service from being deleted.  Unshared the service....still cannot delete it.
MikeMinami
Esri Notable Contributor
So you aren't able to delete the service item from My Content?
Can you provide the URL to the item and we can investigate and delete it.
Mike
JaredCollier
That is correct, I cannot delete from my content page.  If I click the link to get to the ArcGIS REST Services Directory I get 404 not found error.
If I open with arcmap it reads fine, the second url below is from the layer properties source in arcmap.  The first is from the content details page in AGOL.
http://services1.arcgis.com/k2QNgWOTJTnwuT9b/arcgis/rest/services/Juneau+Associates+Inc.%2C+P.C.+Off...
http://services1.arcgis.com/k2QNgWOTJTnwuT9b/arcgis/rest/services/Juneau Associates Inc., P.C. Office Locations/FeatureServer
Thanks.
MikeMinami
We are looking into this.
Mike
DishaGori
As an administrator of an AGOL Subscription account, I can't delete any member's Feature Services either. It says "Deleting...." but doesn't do a thing even after an hour of waiting.
MichaelKastanotis
I am having the same issue when I try to delete this service: http://services.arcgis.com/SvSKeSQcFJgqad7l/arcgis/rest/services/Sewer+Stormwater/FeatureServer
I don't think this service ever worked from the moment I uploaded it. When I click on the link I get "404 - File or directory not found."
Mike
by Anonymous User
Not applicable
If you are unable to delete a service, please contact Esri Support so we can work to get this removed for you. There is an issue with service names that contain a space that will be addressed soon. In the meantime, please submit your requests to Esri Support so we can help delete the service for you.
Thank you,
Andrew
