Type error: Graphis is null
2001
6
10-23-2012 05:56 PM
SK
I added a base layer with spatial reference 102100. When I try to add a point and a symbol to it, it throws an error at
map.graphics.add - graphics is null. Here is my code
var pt= new esri.geometry.Point(x,y,sr);
var sms= new esri.symbol.SimpleMarkerSymbol(...);
var label = new esri.Graphic(pt,sms);
map.graphics.add(label);
Firebug shows label holds the pt and sms values. What could be causing the issue?
StephenLead
Honored Contributor
Note that the help file for graphicsLayer says:
The graphics object is available to use after the Map.onLoad event.
So you should place your code below inside an event which runs once the map has loaded:
dojo.connect(map, "onLoad", function() {
SK
Thanks Stevel. I tried that as well, still it was giving me the same error. Any thoughts?
StephenLead
Honored Contributor
Can you post your whole code (or at least enough to reproduce the problem)?
Cheers,
Steve
__Rich_
Don't forget the map cannot function without a non-Graphics layer:
http://forums.arcgis.com/threads/65475-Graphics-without-a-base-map
SK
Thanks.  Now, I can get the points show up. I am wondering if a text (textsymbol) can be added as below. Text is not showing up. I am not sure if am doing it right. Please help
dojo.connect(map, "onLoad", function(){
      var xy = new esri.geometry.Point ([-13074275.960 , 4015990.240], new esri.SpatialReference({wkid:102100}));
   //var xy =  new esri.geometry.Point([-117.440 , 33.905]  , new esri.SpatialReference({wkid:102100}));
   var sms = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10,
   new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
   new dojo.Color([47,85,89]), 1),
   new dojo.Color([112,15,70]));
   var text =  new esri.symbol.TextSymbol("Hello World").setColor(
    new dojo.Color([128,0,0])).setAlign(esri.symbol.Font.ALIGN_START).setAngle(45).setFont(
    new esri.symbol.Font("12pt").setWeight(esri.symbol.Font.WEIGHT_BOLD)) ;
   var ptlabel= new esri.Graphic(xy,sms,text);
          map.graphics.add(ptlabel);
__Rich_
Could you start a new thread for this separate issue?  (and close off this one by marking the relevant post as the answer)
