limiting the user's view based on log in credentials
1592
10-23-2012 06:57 AM
evanpicard
I've got sales territories across the US.
I want sales managers to be able to log in, and only be able to see data from a nationwide data set limited to their own territory. There is a possibility we'd want some layers limited, and other layers nation-wide.
I'm sure there are round-about ways to do with multiple layers for each territory, but I'd like to tackle this as straight forward as possible.
Can someone point me in the right direction or give me some ideas?  A sample maybe?
Thank you,
Evan
system details - SQL server 2008, ArcGIS Server 10, javascript API
nicogis
if you use feature service you can use defaultDefinitionExpression for filter data http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/featurelayer.htm .
in 10.1 you can also use LayerDataSource for definition source (data native rdbms)  http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/layerdatasource.htm
However for protect you filter you need apply your filter at level of proxy using for example in function of login (server side) a lookup user - filter 'unknown'
evanpicard
Thank you! Yes, definition query makes sense.  But I'm not sure I understand that last part.
Can you please explain?
Thank you!
Evan
nicogis
js (or web client in general) does request client side: a manager log in your app and he can see request with filter (defaultDefinitionExpression ) for his data, so he can do request (rest) for another nationwide data if he understand the logic of criterio filter so you should obfuscate this filter.
