how  to get  the point  of polygon
802
6
10-16-2012 08:15 PM
yanli
how  to  get  four  point  of  Rectangle   polygon  with   arcgis server  for  js
__Rich_
__Rich_
Polygons are made up of rings, rings are made up of points.
This same 'path' can be used following, for example, an Identify operation to get the points of a feature.
yanli
thank  you , can  you  give me    a  example  with  code?
thank  you  very  much
__Rich_
I'm not going to do it all for you 🙂
But here's one approach, assume you've got a polygon (thePoly), perhaps it's the geometry property of a Graphic:
for(var i=0;i<thePoly.rings.length;i++){
    console.log("Getting points from ring #" + i);
    for(var j=0;j<thePoly.rings.length;j++){
        console.log("Point #" + j + " x=" + thePoly.rings[0] + " y=" + thePoly.rings[1] + " (using array access)");
        console.log("Point #" + j + " x=" + thePoly.getPoint(i, j).x + " y=" + thePoly.getPoint(i, j).y + " (using getPoint())");
//Could replace the  access with a call to thePoly.getPoint(i,j) if you like which would return a copy of the Point rather than a reference to the actual Point
(haven't tested the code, just typed straight into this post, should be roughly right though)
yanli
        console.log("Point #" + j + " x=" + thePoly.rings.x + " y=" + thePoly.rings.y);
thank you ,
i have test the code
it  is  failse  to get  x =thePoly.rings.x
it is ok  like  var pt=thePoly.getPoint(i,j); var x=pt.x;
__Rich_
Told you I hadn't tested it 🙂
I assumed that the points in the ring would be stored as Point objects whereas they're actually stored internally as simple arrays - have changed the code above.
Presumably this has answered your question?
