Where to Write Temporary XML Files
1804
10-12-2012 04:00 PM
RandyKreuziger
I'm creating a tool to edit metadata.  The tool will export a feature class's metadata as an XML file, make modification to the file then import it back in.  Where is a safe place for tools to create temporary text and XML files?
curtvprice
I wrote some tools along these lines, and used Windows TEMP.
In ModelBuilder, I got the path from the system environment variable TEMP using the Calculate Value tool. Set the output data type to Folder.
Expression: env("TEMP")
Code Block:
def env(envVar):   import os   return os.environ[envVar]
If you're python scripting, just use os.environ
tmpXML = os.environ["TEMP"] + "/" + "xxtemp.xml"
DaleHoneycutt
If you're using 10.1, you can use the ScratchFolder environment value
curtvprice
Code Block:
RandyKreuziger
Thanks for the solutions.  I tried to mark both your posts as answering the question but the system won't allow it 😞
