Model Builder
1109
10-11-2012 09:54 AM
BenKeller2
I am creating a model to run a set of commands based off a data set containing 750k points. Everything works but my first command where I aggregate the points into polygon clusters where it returns an error. I have read that model builder sometimes bombs if there are too many polygon features to work with, but I just wanted to see if there was a way around it other than making my data set smaller.
Also I have tried minimizing my data set but 200k and it works, but the aggregate points tools returns a different attribute table through model builder than if run natively. This in turn throws off my next command which is a selection based off of the Shape_Area attribute that typical is in the table from aggregate points. I don't want to have to edit the data every time before I run this process because I am planning on setting up an timed automatic run every so often through python. Needless to say the frustration is building....Please help!
Ben
BenKeller2
Scratch that. Just need to know why the Aggregate Points tool outputs a different attribute table when used in Model Builder and when used outside of model builder. I need the Shape_Area attribute field, for selection purposes, in model builder and it is not there, along with Shape_Length. (Only returns ID and Shape).
Thank you
DaleHoneycutt
Sounds like you're writing to a shapefile instead of a geodatabase.  The reason is probably because your scratch workspace environment is set to a folder instead of a geodatabase.  There are a couple of ways to fix this:
- In ModelBuilder, make sure that the output of Aggregate Points is being written to a geodatabase (file or personal--I recommend personal).
- Set you Scratch Workspace environment variable to a geodatabase.  I suspect it's set to a folder.
Using the current and scratch workspace environments explains scratch workspace and autogenerate output names (interesting stuff is at the bottom of the topic).
curtvprice
Dale wasn't totally clear on that. Geodatabase feature classes automatically create Shape_Area and Shape_Length fields when they are created. Shapefile output doesn't have either of these fields.
Really Dale - that's the first time i've heard personal geodatabases recommended! Care to elaborate?
DaleHoneycutt
Curtis -- you're absolutely right... my mistake (late night typo).  I would never recommend personal geodatabases...  File geodatabases all the way! Thanks for catching this!
Dale
