Possible to use OpenLayers in JS API (not other way around)
5104
12
10-04-2012 08:37 AM
JeffPace
I know there are lots of examples of how to use ESRI resources in OpenLayers, i want to do the opposite.  Is there anyway to get a OpenLayer to display in a ESRI JS API application?
a sample would be really really useful.  Thank you.
NianweiLiu
Attached sample should be what you are looking for. However to make it generically usable you need consider basemap coordinate system, cache scheme switch and other WMS specific issues. Basically
getTileUrl: function(level, row, col) {                   var url = '';                   var lv = this.tileInfo.lodsByLevel[level];                   if (lv) {                     var xmin = (col) * this.tileInfo.width * lv.resolution + this.tileInfo.origin.x;                     var ymin = this.tileInfo.origin.y - (row + 1) * this.tileInfo.height * lv.resolution;                     var xmax = (col + 1) * this.tileInfo.width * lv.resolution + this.tileInfo.origin.x;                     var ymax = this.tileInfo.origin.y - (row) * this.tileInfo.height * lv.resolution;                     url = this.url +                     '?SERVICE=WMS&REQUEST=GetMap&TRANSPARENT=true&FORMAT=image/png&VERSION=1.3.0' +                     '&LAYERS=' + this.layers + '&BBOX=' + xmin + "," + ymin + "," + xmax + "," + ymax +                     '&CRS=EPSG:' + this.tileInfo.spatialReference.wkid +                     '&WIDTH=' + this.tileInfo.width + '&HEIGHT=' + this.tileInfo.height +'&STYLES=';                   }                   return url;                 }
Full code in attachment.
derekswingley1
What do you want to do with OpenLayers?
SamLarsen
OpenLayers consumes layers from many different formats.  There is no 'OpenLayers' service to be consumed by other APIs.
Some commonly used layer types in OpenLayers include OpenStreetMap, WMS, WFS, TMS, KML, GeoRSS etc..
You can find many of these layer types also in the JavaScript API:
OpenStreetMapLayer
TiledMapServiceLayer
WMSLayer
WMTSLayer
KMLLayer
GeoRSSLayer
JeffPace
I have a WMS server I want to make tiled requests of.  It is not WMTS, only WMS.  OpenLayers handles this but I cant seem to figure out how to do it in the api.
Basically, i cant make level row col type requests, i need to make individual bounding box requests
   var wms = new OpenLayers.Layer.WMS("NASA Global Mosaic",
                                       "http://wms.jpl.nasa.gov/wms.cgi",
                                       {layers: "modis,global_mosaic"});
makes tiled requests, unless you set a singletile parameter, in which case it behaves as ESRI WMS
                                           layers: "modis,global_mosaic",
                                           transparent: true
                                           opacity: 0.5,
                                           singleTile: true
NianweiLiu
I'd try extend TiledMapServiceLayer, take the base map's tileInfo, run a few calculations to get the extent based on the row, level passed in by getTileUrl and construct the right WMS request.
Bring in openlayers seems quite a large overhead.
JeffPace
agreed.  OK off to send if i can do this.
KellyHutchins
Esri Notable Contributor
JeffPace
yes i saw that, but i cant make row/col/level type requests, i need to make boundingbox width height type requests.
derekswingley1
I'm having a hard time understanding this. A bbox request is issued, but multiple images come back? Maybe OpenLayers is doing something different under the hood.
Is there a public example of OpenLayers using this service somewhere?
JeffPace
no no sorry.
when openlayers requests a wms image, you can choose two styles set via property.  If you choose "singleTile" it returns a single image, just like the esri WMS layer
if you do not set "singleTile", it sends a series of bbox/width/height requests (tile like requests), and assembles them, just like an esri tile layer.  However the requests are not /level/col/row format, they are bbox/width/height format (in the url).
http://www.mymanatee.org/lizardtech/iserv/docs/samples/wms-ajax-view.html
var wms = new OpenLayers.Layer.WMS("MODIS 2002",
    "http://MCG-AP-GISAPP01.mcgad.local/lizardtech/iserv/ows",
    {layers: 'MODIS',
    exceptions:"application/vnd.ogc.se_xml"},
    {tileSize: new OpenLayers.Size(256, 256), buffer: 1});
  map.addLayer(wms);
