How to Register Geodatabases with ArcGIS Server using REST Server Admin API
4313
10-01-2012 01:21 AM
RobertWard
I'm trying to register a geodatabase with an ArcGIS server using a Python script but there is very little documentation on how to do it.
The script I have at the moment is:
# Function to register a geodatabase with an ArcGIS Server
def registerGeodatabase(server, port, geodatabase, adminUser, adminPass, token=None):
    addCustMsg("Registering geodatabase : " + geodatabase)
    # Get and set the token
    if token is None:
        token = gentoken(server, port, adminUser, adminPass)
    prop_dict = { "type": "egdb",
                        "path": "/enterpriseDatabases/" + geodatabase,
                        "id": "",
   "clientPath": ""
    wrapper_dict = { "item": prop_dict }
    wrapper_encode = urllib.urlencode(wrapper_dict)
    print wrapper_encode
    create = "http://{}:{}/arcgis/admin/data/registerItem?token={}&f=json".format(server, port, token)
    status = urllib2.urlopen(create, wrapper_encode).read()
    if 'success' in status:
        arcpy.SetParameter(6, True)
    else:
        arcpy.SetParameter(6, False)
        arcpy.AddError(status)
    return
From registering a geodatabase to the ArcGIS server using the ArcGIS manager I have worked out I need to upload the database connection file using:
Register Item - http://server:port/arcgis/admin/uploads/register
Upload Part - http://server:port/arcgis/admin/uploads/<itemID>/uploadPart
Commit Item - http://server:port/arcgis/admin/uploads/<itemID>/commit
The database connection file will have an itemID to uniquely identify it, how to I reference the database connection file in the RegisterDataItem REST call:
http://server:port/arcgis/admin/data/registerItem
 item={
  "path": "<path>",
  "type": "<datadir|folder|fgdb|egdb|dataset>",
  "id": "<id>",
  "clientPath": "<client-path>"
Using the ArcGIS Manager to register the geodatabase suggests it extracts the contents of the uploaded database connection file into a string but I can't find how this is done.
Any suggestions?
KevinGooss
Is that toolset exposed in ArcCatalog? I seem to recall that it is only available as python tools.
but if it were a tool in ArcCatalog you could run it from there and see the python being cranked out.
RobertWard
Tried that trick for some other tasks but I can't find a tool to register a geodatabase with an ArcGIS Server.
PatriceFREYDIERE
There is a System GeoProcessor that aim to get the connectionstring from the .sde file, and permit to register by script the database.
1 - upload the .sde file using uploads admin rest endpoint
2 - use the /"Get Database ConnectionString" Geoprocessing function of the PublishingTools 's System folder
     -> using fiddler you can trace the parameters and calls from the manager.
3 - Register the database with proper JSON String using /registerItem
KevinHibma
I know the question asks specifically how to use the REST Admin to register a data source -
However at 10.1 SP1 we added the following to arcpy:
AddDataStoreItem
ListDataStoreItems
RemoveDataStoreItem
ValidateDataStoreItem
Hopefully you find these as an easier and more straight forward approach to adding items to the data store.
