Script for Con Isnull processing
969
09-11-2012 06:16 AM
ChadMahoney
I am tasked with processing satellite images (4000) and need to convert zero values to nodata. I figured that the con isnull function would be the best. I have worked on this script taking bits and pieces from various scripts I use and/or found online. I get this error "Cellsize or analysis window are not set"
If anyone could help that would be great. Below is the script I am working with in 9.3
# Import system modules
import sys, csv, time, calendar, datetime, string, os, arcgisscripting
# from datetime import date, timedelta
# Create the Geoprocessor object
gp = arcgisscripting.create()
gp.SetProduct("ArcView")
gp.CheckOutExtension("Spatial")
# Load required toolboxes...
gp.AddToolbox("C:/Program Files (x86)/ArcGIS/ArcToolbox/Toolboxes/Spatial Analyst Tools.tbx")
#Set the input workspace
gp.workspace = "C://Users//GIS Specialist//Desktop//SUMD//By Hour//00_15"
#GP.AddMessage(str(GP.workspace))
#Set the output workspace
outworkspace = "C://Users//GIS Specialist//Desktop//SUMD//Processed By Hour//00_15"
#Get a list of the featureclasses in the input folder
rasters = gp.ListRasters()
#Reset the enumeration to make sure the first object is returned
rasters.Reset()
    #Loop through the list of feature classes
raster = rasters.Next()
while rasters:
    #expression for the reclass where nodata is reclassed to 0
    expression = "con(isnull(" + raster + "), 0, " + raster + ")"
    #name and location of the raster output
    outputRaster = outworkspace + "/" + raster
    gp.SingleOutputMapAlgebra_sa(expression, outputRaster)
