Toggle Visibility of Features in FeatureLayer
1856
09-06-2012 06:45 AM
ManojrajTeli
How to toggle the visibility of features in a feature-layer using check-boxes .I have grid containing check-boxes in a columns and so if i check off the checkbox i can turn off the visibility and if i check in turn on the visibility using ArcGIS javascript Api 3.1.Thank you in advance.
CraigMcDade
I started with this sample and modified it to meet my needs. It sounds like what you are trying to do.
nathanmanning
Are you trying to toggle visibility of an entire layer or individual graphics within a layer?
ManojrajTeli
I am trying to toggle visibility of individual graphics within a layer.:confused:
nathanmanning
If it's not a performance issue, each time you toggle visibility with the check boxes you could iterate over your graphics array and toggle visiblity. You just need some way to identify each graphics and correlate it with the check boxes. Adding a simple "name" attribute might be sufficient.
