add shapefile to Map But not upload file to server
983
09-05-2012 05:01 AM
AmmarAssem1
I work in project javascript with esri api
In this example
http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/portal_addshap...
the end user should upload shapefile if already i have shape and need to display it into map but the problem in the example code take the file from the form data
if there are any way to path file directly without upload file or code that serialize shapefile to featurecollection json
thanks 🙂
