Cannot deploy SOE
2403
09-04-2012 11:19 AM
PeterSouth
Hello everyone,
I'm testing the new SEO REST functionality.
I created a new project in VS2010 with the SOAP template and a basic "hello world" project was created. After making a build, I'm trying to deploy de .soe with no luck.
I'm following these steps: http://resources.arcgis.com/en/help/main/10.1/index.html#/Deploying_a_server_object_extension/015400...
After step 5 I get the message "Please wait while extension is being added..." but it never leaves.
No traces on the log.
What could be the problem?
KevinGooss
Did you try to build it again in a different solution just to see if it was a fluke?
what version of studio are you using?
i have heard about issues with which was installed first and all that jazz.
PeterSouth
Thanks for reply Kevin.
Using VS2010 Ultimate, Version 10.0.40219.1 SP1Rel
Things I've tried with no luck:
- Build the default solution and use it's soe generated file.
- Rebuild the default solution and use it's soe generated file.
- Create new default solution and use it's soe generate file.
- Download the "ServerFindNearSOAPSOE" sample from esri and use it's soe file.
- Restart the arcgis service.
Everything is done in the same machine where the ArcGIS Server is installed: Windows Server 2008 R2, 64bits.
Is there any setting needed to add an extension?
Any ideas?
PeterSouth
Found the solution.
I was using IE9.
Works perfect with Google Chrome.
No comments.
KevinGooss
Oh geez. Never even thought about that. oh well.
