Problem with coding on ExportXYv_stats  tool
1712
09-03-2012 04:38 PM
NickEubank
Hi All!
I'm having issues with the arcpy tool arcpy.ExportXYv_stats. According to the documentation, the tool accepts 5 arguments, but I can't get the tool to accept the final argument, which determines whether variable labels will be included in an exported ASCII file. (I'm running Arc 10).
Any advice?
Thanks!
by Anonymous User
Not applicable
Can you post the full code? I have included this function in many scripts for creating spreadsheets for the non-GIS people in my office. Here is what it looks like in one of my scripts:
import arcpy, os, sys, traceback
arcpy.env.workspace = 'G:\\Data\\Geodatabase\\Cedar_County.mdb'
infeat = 'G:\\Data\\Geodatabase\\Cedar_County.mdb\\SOILS\\SOILS_BY_PARCEL'
outputpath = 'O:\\CSR_Report\\'
dissolveoutpath = 'G:\\PROJECTS\\Cedar\\Soils\\testing\\'
outfeat = dissolveoutpath + 'dissolve.shp'
out_table = outputpath + 'CSR_Report.csv'
dfield = "PID"
statfield = "WEIGHTED_AVERAGE_CSR FIRST; SUM_ FIRST"
dfield = ['PID']
expression = "!FIRST_WEIG!"
expression2 = "!FIRST_SUM_!"
dropfields = ["FIRST_WEIG", "FIRST_SUM_"]
try:
    print "Starting Dissolve..."
    arcpy.Dissolve_management(infeat, outfeat, dfield, statfield,
                              "MULTI_PART", "DISSOLVE_LINES")
    arcpy.AddField_management(outfeat, "AVE_CSR", "FLOAT")
    arcpy.CalculateField_management(outfeat, "AVE_CSR", expression,
                                    "PYTHON")
    arcpy.AddField_management(outfeat, "TOTAL_CSR", "FLOAT")
    arcpy.CalculateField_management(outfeat, "TOTAL_CSR", expression2,
                                    "PYTHON")
    print 'Cleaning table'
    arcpy.DeleteField_management(outfeat, dropfields)
    print 'Dissolve finished, now converting table to CSV'
    fieldnames = [f.name for f in arcpy.ListFields(outfeat)]
    arcpy.ExportXYv_stats(outfeat, fieldnames, "COMMA", out_table,
                          "ADD_FIELD_NAMES")
    print 'CSR table created sucessfully'
except:
    arcpy.AddError(arcpy.GetMessages(2))
by Anonymous User
Not applicable
I have had a lot of problems with that tool as well, it seems to always have strange behavior.  I have just been using a work around and creating text files manually.  Here is an example:
 print 'Creating Text File...'
    text = open(p.join(ws, "Addresses2.txt"), "w")
    text.writelines('"Parcel_ID"\t"FULL_ADD"\t"POINT_X"\t"POINT_Y"')
    srows = arcpy.SearchCursor(address)
    for row in srows:
        pid = row.getValue('PID')
        add = row.getValue('FULL_ADD')
        x   = row.getValue('POINT_X')
        y   = row.getValue('POINT_Y')
        text.writelines('\n"%s"\t"%s"\t%f\t%f' % (pid,add,x,y))
    text.close()
    del row, srows
    print 'Text File Created Successfully'
This script uses a search cursor to grab the values from a table and writes them out into a text file.  This one is tab delimited, but it can easily be changed to comma delimited by replacing the \t with a comma.  If you don't have a lot of fields to write out this could be used as a work around.
