Changes to "Visibility" using FieldInfo method not working?
865
11-20-2012 08:21 AM
JonathonBruce
Hello all,
In the code below, I can get the python window in arcmap to show that the visibility flag is being changed for the apprpriate fields, but the changes aren't being reflected in the new feature layer's attribute table. I've tried updating the MXD, the active view, all sorts of things. Any help would be appreciated.
try:
    layer = pythonaddins.GetSelectedTOCLayerOrDataFrame()
    fldInfo = arcpy.FieldInfo()
    KeepList = ['Loc_name','Match_type','Match_addr']
    for field in arcpy.ListFields(layer):
        if field.name in list(KeepList):
            fldInfo.addField(field,field ,"VISIBLE","")
            if field.name not in list(KeepList):
                fldInfo.addField(field,field,"HIDDEN","")
except:
    Problem()
else:
    arcpy.MakeFeatureLayer_management(layer, "Formatted","","",fldInfo)
