Recursive conversion from shp to FileGDB through folders and subfolders
1760
5
04-20-2012 09:30 AM
JonathonBruce
I'm trying to convert all shapefiles into feature classes in my directory, including what's inside sub-folders. The code that I've compiled below (from reading previous answers and trial & error on my part) accomplishes this, but it seems that it also begins to iterate through the newly created GDB as well, which is bad. Any advice or insight would be greatly appreciated.
import arcpy from arcpy import env import os  path = 'C:\\Data' env.workspace = path  arcpy.management.CreateFileGDB(env.workspace,"Project","10.0")   try:     def fcs_in_workspace(workspace):         env.workspace = workspace         for fc in arcpy.ListFeatureClasses():             yield fc         for ws in arcpy.ListWorkspaces():             for fc in fcs_in_workspace(os.path.join(workspace, ws)):                 yield fc          OutGDB = env.workspace +'\\Project.gdb'       for fc in fcs_in_workspace(env.workspace):           arcpy.FeatureClassToGeodatabase_conversion(fc,OutGDB)           print(fc +' copied.')                          except Exception as e:     print(e) else:     env.workspace = path     arcpy.CompressFileGeodatabaseData_management(OutGDB)     print(OutGDB + " has been compressed.")
DarrenWiens2
Is "for fc in fcs_workspace(env.workspace):" supposed to be "for fc in fcs_in_workspace(env.workspace):"? Also, is the indentation above truly correct? It doesn't look like you ever actually call the function "fcs_in_workspace".
In any case, you should somewhere test "if workspace != 'Project.gdb': ", or remove the workspace from your list of workspaces altogether.
DarrenWiens2
JonathonBruce
No, the indentation isn't correct and thanks for the catch on fcs_in_workspace. Nerves got the best of me while I was setting up, with it being my first post and all. I will test the != idea and get back to you. Thanks!
JonathonBruce
Your idea worked! Here is the code as of current:
import arcpy,os
path = 'E:\\GDBConversionProject\\2062 Cabin Bluff'
try:
            yield fc
                if ws != path +"\\Project.gdb":
                    yield fc
    print(e)
else:
    print("Compressing FileGDB.")
MichaelVolz
Esteemed Contributor
Question about the importance of this script:
Is this your companies (organization's) policy to convert shapefiles to file geodatabases?
Or is ESRI dictating this move because shapefiles are going to be deprecated in the near future?
JonathonBruce
It was an internal company shift from shapefiles to FGDB's.
