Extent.intersects() method returns incorrect value
3508
09-03-2012 07:59 AM
SamLarsen
I am using the esri.geometry.Extent.intersects() method which is returning a boolean true or false based on whether or not the extent intersects the other extent.
The documentation states that it should return the actual intersection extent:
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi_start.htm#jsapi/extent.htm#intersects
Is this a case of the documentation being incorrect or the API being incorrect?
SamLarsen
It appears that the API is correct and the documentation is incorrect or out of date.
For those looking for an actual intersection extent i have extended the API to generate the extent:
dojo.extend(esri.geometry.Extent,{  intersection: function(/*esri.geometry.Extent*/ extent) {   //  summary:    //    Calculate the intersection extent of two extents   //  returns:   //    The intersection extent   //    esri.geometry.Extent || null   var overlap = null;   if(this.intersects(extent)){    //  create a new intersection geometry    overlap = new esri.geometry.Extent(     this.xmin > extent.xmin ? this.xmin : extent.xmin,     this.ymin > extent.ymin ? this.ymin : extent.ymin,     this.xmax < extent.xmax ? this.xmax : extent.xmax,     this.ymax < extent.ymax ? this.ymax : extent.ymax,     this.spatialReference    );   }   return overlap;  } });
SamLarsen
derekswingley1
Hi Sam,
esri.geometry.Extent.intersects does return an extent when an extent is passed to it and the two extents intersect. Here's a test case:  http://jsfiddle.net/w45HY/
If you're not passing an extent to extent.intersects() (that is, you pass some other geometry type like Point or Polygon), you get a boolean back. Can you confirm that this works on your end?
Edit:  we'll update the docs to say that a boolean is returned if a non-extent geometry is passed to extent.intersects().
