runtime performance
659
09-02-2012 02:08 AM
GhassanKarwchan
I have a feature class with 7000 features
When I load the map, it is taking almost 20 seconds to load the map.
Comparing with  the original application that used ArcGIS engine, which was taking 2 seconds, I am not sure if I am going to go further.
any idea about the performance?
MiriRevivo
Have you tried using AcceleratedDisplay?
You can either do that for the whole map by setting the map's UseAcceleratedDisplay property to True, or for a group of layers by placing the layers in the AcceleratedDisplayLayers group.
This should make things a lot faster (it draws using in a different pipeline, which was especially written by esri to increase drawing performance).
AnttiKajanus1
Like vpitzi said,
Use AcceleratedDisplay and be sure that the symbol that use is supported by the Acceleration. Also check from Samples Mapping / Accelerated Display examples.
http://resources.arcgis.com/en/help/runtime-wpf/apiref/index.html?ESRI.ArcGIS.Client~ESRI.ArcGIS.Cli...
