GeometryService - basic or standard
1741
09-03-2012 06:09 AM
ItamarKcholi
I wanted to know if the GeometryService can be used in the basic or just in the standard license level.
Itamar
MiriRevivo
Hey Itamar 🙂
I assume your question refers to working in a disconnected mode (without ArcGIS Server in the picture)?
Since the GeometryService needs a LocalServer to run upon, and spinning up the LocalServer requires a Standard license - you will be needing the Standard license.
If, on the other hand, your GeometryService runs on the Server, then you only need Basic in order to work with it.
Hope this helps,
Miri.
MiriRevivo
Hey Itamar 🙂
Hope this helps,
Miri.
ItamarKcholi
Hey Miri,
Yes i am working in a disconnected environment.
Itamar
