outdated path for imported module ???
1364
08-24-2012 02:10 AM
JohannaTorppa
I have a python script, running in ArcGIS, that evidently tries to import a module from an outdated location. I get an error message and Traceback info:
File "x://outdated_path/SDMmodule.py", line 25, in appendSDMValues ....etc
However, the module script SDMmodule.py is no more in that location, and I did not find a reason why it tries to find it from there. The module script SDM module.py is in the same directory as the main script, in a totally different location.
JakeSkinner
Esri Esteemed Contributor
Hi Johanna,
Python looks in the directories that are part of the module search path. These directories
are listed in the sys.path variable from the sys module.  To list where the Python looks for modules, print out the value of the sys.path variable. For example:
import sys
print sys.path
If the previous path of this module is located there, this could be the reason you are receiving this error.  You can remove the path by using sys.path.remove.
JohannaTorppa
Thanks Jake, sounds reasonable. I'll try that on monday.....
Hi Johanna,
import sys
print sys.path
JohannaTorppa
The system variable sys.path does not contain the outdated directory where the module is being searched from. And I have manually appended there the correct module directory. But still the same error occurs.
Johanna
Hi Johanna,
import sys
print sys.path
