Python Addin ComboBox, Passing Selection into Definition Query
5173
6
08-21-2012 10:39 AM
MikeMacRae
I am trying to pass the users selection into a definition query in an addin combo box python script.
Basically, I have a feature class with a field called "SITE". I build a python list from that field and pass it into the combo box items list. The user will choose a value in the combo box box from that list. I want to further pass the users selection into a definition query.
You can see in my script below, I just tried to pass the selection into the definition query, but it crashes the whole combo box and toolbar (i.e. when I reinstall my addin, the tool shows up on my toolbar in big red letters "MISSING"). Obviously I am doing something wrong it I believe it's how I'm passing the selection. As suggestions?
import arcpy
import pythonaddins
sitename = []
for row in arcpy.SearchCursor("Z:\JACOS\Data\GIS\Geodatabases\JACOS_MASTER_2011_PDA_CR.gdb\IF_PDABNDY_R"):
    sitename.append(row.SITE)
class ComboBoxClass(object):
    """Implementation for SolsticeFigureUpdater_addin.combobox (ComboBox)"""
    def __init__(self):
        #self.items = ["item1", "item2"]
        self.items = sorted(sitename)
        self.editable = True
        self.enabled = True
        self.dropdownWidth = 'WWWWWWWWWWWWWW'
        self.width = 'WWWWWWWW'
    def onSelChange(self, selection):
        mxd = arcpy.mapping.MapDocument("CURRENT")
        for df in arcpy.mapping.ListDataFrames(mxd):
            if df.name == "DFMAIN":
                dfmain = arcpy.mapping.ListDataFrames(mxd, "DFMAIN")[0]
            if df.name == "DFINSET":
                dfinset = arcpy.mapping.ListDataFrames(mxd, "DFINSET")[0]
        for lyr in arcpy.mapping.ListLayers(mxd, "", dfmain):
            if lyr.name == "PDA Boundary":
                lyr.definitionQuery = '"SITE" =' selection
        arcpy.RefreshActiveView()
        arcpy.RefreshTOC()
    def onEditChange(self, text):
        pass
    def onFocus(self, focused):
        pass
    def onEnter(self):
        pass
    def refresh(self):
        pass
JustinShepard
Does your selection need to be inside a set of quotes? Can you send the selection to a MessageBox so that we can see what exactly is getting passed?
MikeMacRae
Hey Justin, thanks for the response.
I tried to place the selection in quotes like:
lyr.definitionQuery = '"SITE" = selection'
and
lyr.definitionQuery = '"SITE" = "selection"'
and
lyr.definitionQuery = '"SITE" = 'selection'
but it either crashes the combo box or just adds the 'selection' variable as a text string.
I'm thinking the selection in
is the variable used to store the selection the user makes from the combo box (I could be wrong, this is my first python combo box) I thought it would be easy just to pass that into the definition query. I even tried to convert it to string
lyr.definitionQuery = '"SITE" =' str(selection)
but no luck. Obviously I'm mistaking the functionality of that variable....
JustinShepard
we might be overthinking this. There's a + missing in appending your strings.
Example is:
strQPrefix = "\"Named\" ="
strSelection = "'Snow, Peak Mt.'"
strDFQuery = strQPrefix + strSelection
print strDFQuery
layerTarget.definitionQuery = strDFQuery
* the \" is an escape so that python treats the " following the slash as a character and not an indication of a string start or finish
* the strSelection = "'Snow, Peak Mt.'" would get changed for you to something more like strSelection = "'" + selection + "'"
* instead of print try pythonaddins.MessageBox(strDFQuery)
MikeMacRae
You're right Justin. This was simpler than I made it out to be. We both came to the same conclusion at the same time. This is what worked for me:
lyr.definitionQuery = '"SITE"' + "=" + "'" + selection + "'"
The crashing of the addin with some of my other approaches made me think the selection variable was returning in some weird format which took me in a huge tangent.
Cheers,
Mike
OLANIYANOLAKUNLE
import arcpy
import pythonaddins
sitename = []
    def __init__(self):
        self.enabled = True
        arcpy.RefreshTOC()
        pass
        pass
    def onEnter(self):
        pass
    def refresh(self):
        pass
Please mike i am trying to get something very close to what you've posted - i have a field called Name_Allottee and i also want to create a list from this attributes and pass it into my combo box and further drill down with a layer definition query, this is my code can you help me please? Thanks
import arcpy
import pythonaddins
class SelectPlotComboBoxClass(object):
    """Implementation for SelectPlot_addin.combobox (ComboBox)"""
    def __init__(self):
        Name_Allottee = []
        for row in arcpy.SearchCursor("KWAGIS_Parcels"):
            Name.append(row.OBJECTID)
        self.items = sorted(Name_Allottee)
        self.enabled = True
        self.dropdownWidth = 'WWWWWWWWWWWWWWWWWWWW'
        self.width = 'WWWWWWWWWWWWWWWWWWWWWWWWWWWWWW'
            if df.name == "Layers":
                dfmain = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
            #if df.name == "DFINSET":
                #dfinset = arcpy.mapping.ListDataFrames(mxd, "DFINSET")[0]
        Name_Allottee = []
            Name_Allottee.append(row.OBJECTID)
        for lyr in arcpy.mapping.ListLayers(mxd, "", Layers):
            if lyr.name == "KWAGIS_Parcels":
                lyr.definitionQuery = '"Name_Allottee"' + "=" + "'" + selection + "'"
        arcpy.RefreshTOC()
        pass
        pass
    def onEnter(self):
        pass
    def refresh(self):
        pass
I also got a big red mark when i tried to install the addin.
OLANIYANOLAKUNLE
import arcpy
import pythonaddins
sitename = []
    def __init__(self):
        self.enabled = True
        arcpy.RefreshTOC()
        pass
        pass
    def onEnter(self):
        pass
    def refresh(self):
        pass
import arcpy
import pythonaddins
    def __init__(self):
        Name_Allottee = []
        self.enabled = True
        Name_Allottee = []
        arcpy.RefreshTOC()
        pass
        pass
    def onEnter(self):
        pass
    def refresh(self):
        pass
