I'm running into an issue where I'm not able to return a list of results into a data grid. I'm able to make the code work from the "Show Find Task results in DataGrid" section in the Samples section. So originally I used the text box to enter criteria. Works fine. I then decided I needed to control the criteria entered and sent so I replaced the text box with an input select. It works while keeping the form element's ID the same-makes sense. However when I change the input select to a dojo input filteringselect it fails to return the data into the data grid.
It appears the criteria is being sent as I can see it when I wrap JS alerts around the values: alert(dojo.byId("ownerName").value); alert(findParams.searchText);
It appears the grid load fails grid here: grid.setStore(store); I'm developing and testing to IE8. Using Firebug in FF it appears the store variable doesn't contain the records. I'm not getting any errors so hopefully it's an easy fix. Any help would be great. Thanks!
catch(e){
if (newSub.getAttribute("slang").toLowerCase() != code_l.toLowerCase()) {
if (trLabelsHtml != "") {
var labelSname = "";
if(labelEle[i].querySelector("ul li:nth-child(1)").getAttribute("aria-hidden")){
labelSname = labelEle[i].querySelector("ul li:nth-child(1)").outerHTML;
labelEle[i].innerHTML = "";
labelEle[i].innerHTML = labelSname + trLabelsHtml;
catch(e){
/* V 2.0:3 = Store not translated reply id */
if(lingoRSXML.snapshotLength == 0){
if($scope.falseReplyID == "") {
$scope.falseReplyID = value;
/* Get translated Body of Replies/Comments */
var lingoRBXML = doc.evaluate(lingoRBExp, doc, null, XPathResult.UNORDERED_NODE_SNAPSHOT_TYPE, null);
for(var i=0;i 0) {
var attachDiv = rootElement.querySelector('div.lia-quilt-row-main').querySelector('div.custom-attachments');
if (attachDiv) {
attachDiv = attachDiv.outerHTML;
else if(rootElement.querySelector('div.lia-quilt-row-main').querySelectorAll('#attachments').length > 0){
if ("ForumTopicPage" == "BlogArticlePage") {
attachDiv = rootElement.querySelector('div.lia-quilt-row-main .lia-message-body-content').querySelector('#attachments');
if (attachDiv) {
else{
attachDiv = "";
}else{
attachDiv = rootElement.querySelector('div.lia-quilt-row-main').querySelector('#attachments').outerHTML;
else {
attachDiv = "";
/* Feedback Div */
var feedbackDiv = "";
var feedbackDivs = rootElement.querySelector('div.lia-quilt-row-main').querySelectorAll('div.lia-panel-feedback-banner-safe');
if (feedbackDivs.length > 0) {
for (var k = 0; k < feedbackDivs.length; k++) {
feedbackDiv = feedbackDiv + feedbackDivs[k].outerHTML;
else {
var attachDiv = rootElement.querySelector('div.lia-message-body-content').querySelector('div.Attachments.preview-attachments');
if (attachDiv) {
} else {
attachDiv = "";
/* Everyone tags links */
if (document.querySelectorAll("div.TagList").length > 0){
var everyoneTagslink = document.querySelector('div.lia-quilt-row-main').querySelector(".MessageTagsTaplet .TagList");
if ((everyoneTagslink != null)||(everyoneTagslink != undefined)){
everyoneTagslink = everyoneTagslink.outerHTML;
else{
everyoneTagslink = "";
/* Feedback Div */
var feedbackDivs = rootElement.querySelector('div.lia-message-body-content').querySelectorAll('div.lia-panel-feedback-banner-safe');
for (var m = 0; m < feedbackDivs.length; m++) {
feedbackDiv = feedbackDiv + feedbackDivs[m].outerHTML;
} catch (e) {
if (body_L == "") {
/* V 2.0:7 Replacing translated video data with source video data */
var newBodyVideoData = newBody.querySelectorAll('div[class*="video-embed"]');
angular.forEach($scope.videoData[value], function (sourceVideoElement, index) {
if (index <= (newBodyVideoData.length - 1)) {
newBodyVideoData[index].outerHTML = sourceVideoElement.outerHTML
/* V 2.0:7 = Replacing translated image data with source data */
var newBodyImageData = newBody.querySelectorAll('[class*="lia-image"]');
angular.forEach($scope.imageData[value], function (sourceImgElement, index) {
if (index <= (newBodyImageData.length - 1)) {
newBodyImageData[index].outerHTML = sourceImgElement.outerHTML;
/* V 2.0:7 = Replacing translated pre tag data with source data */
var newBodyPreTagData = newBody.querySelectorAll('pre');
angular.forEach($scope.preTagData[value], function (sourcePreTagElement, index) {
if (index <= (newBodyPreTagData.length - 1)) {
newBodyPreTagData[index].outerHTML = sourcePreTagElement.outerHTML;
var copyBodySubject = false;
if (body_L == "") {
copyBodySubject = true;
body_L = newBody.innerHTML;
/* This code is written as part of video fix by iTalent */
/* try{
var iframeHTMLText = body_L;
var searchIframeText = "<IFRAME";
var foundiFrameTag;
if (iframeHTMLText.indexOf(searchIframeText) > -1) {
foundiFrameTag = decodeHTMLEntities(iframeHTMLText);
foundiFrameTag = foundiFrameTag.split('src="')[1];
body_L = foundiFrameTag;
catch(e){
/* This code is placed to remove the extra meta tag adding in the UI*/
try{
body_L = body_L.replace('<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />','');
catch(e){
/** We should not replace the source content if user profile language and selected target language matches with source language **/
if(showTrContent) {
var compiled = false;
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = null
if("ForumTopicPage"=="IdeaPage"){
// var customAttachDiv = '';
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = body_L + feedbackDiv ;
$compile(rootElement.querySelectorAll('div.lia-message-body-content')[0])($scope);
compiled = true;
/* Attach atttach div */
// document.querySelector("div.translation-attachments-"+value).innerHTML = attachDiv;
rootElement.querySelectorAll('div.lia-message-body-content')[0].insertAdjacentHTML('afterend',attachDiv);
if(rootElement.querySelectorAll('div.lia-quilt-idea-message .lia-message-body .lia-attachments-message').length > 1){
rootElement.querySelectorAll('div.lia-quilt-idea-message .lia-message-body .lia-attachments-message')[1].remove();
} else {
if("ForumTopicPage"=="TkbArticlePage"){
}else{
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = body_L + feedbackDiv + attachDiv;
compiled = true;
/* Destroy and recreate OOyala player videos to restore the videos in target languages which is written by iTalent as part of iTrack LILICON-79 */ /* Destroy and recreate OOyala player videos */
try{
// $scope.videoData[value][0].querySelector("div").getAttribute("id");
for(var vidIndex=0; vidIndex<$scope.videoData[value].length; vidIndex++){
if( $scope.videoData[value][vidIndex].querySelector("div") != null){
var containerId = LITHIUM.OOYALA.players[$scope.videoData[value][vidIndex].querySelector("div").getAttribute("id")].containerId;
videoId = LITHIUM.OOYALA.players[$scope.videoData[value][vidIndex].querySelector("div").getAttribute("id")].videoId;
/** Get the Video object */
vid = OO.Player.create(containerId,videoId);
/** Destroy the video **/
vid.destroy();
/** recreate in the same position */
var vid = OO.Player.create(containerId,videoId);
catch(e){
try{
for(var vidIndex=0; vidIndex<($scope.videoData[value].length); vidIndex++){
if($scope.videoData[value][vidIndex].querySelector('video-js') != null){
var data_id = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-video-id');
var data_account = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-account');
var data_palyer = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-player');
var div = document.createElement('div');
div.id = "brightcove";
div.class = "brightcove-player";
div.innerHTML =
'(view in my videos)'
var data = div.getElementsByClassName("video-js");
var script = document.createElement('script');
script.src = "https://players.brightcove.net/" + data_account + "/" + data_palyer + "_default/index.min.js";
for(var i=0;i< data.length;i++){
videodata.push(data[i]);
for(var i=0;i< videodata.length;i++){
document.getElementsByClassName('lia-vid-container')[i].innerHTML = videodata[i].outerHTML;
document.body.appendChild(script);
catch(e){
if(!compiled){
/* Re compile html */
if (code_l.toLowerCase() != newBody.getAttribute("slang").toLowerCase()) {
/* Adding Translation flag */
var tr_obj = $filter('filter')($scope.sourceLangList, function (obj_l) {
return obj_l.code.toLowerCase() === newBody.getAttribute("slang").toLowerCase()
if (tr_obj.length > 0) {
tr_text = "Esri may utilize third parties to translate your data and/or imagery to facilitate communication across different languages.".replace(/lilicon-trans-text/g, tr_obj[0].title);
try {
if ($scope.wootMessages[$rootScope.profLang] != undefined) {
tr_text = $scope.wootMessages[$rootScope.profLang].replace(/lilicon-trans-text/g, tr_obj[0].title);
} catch (e) {
} else {
//tr_text = "This message was translated for your convenience!";
tr_text = "Esri may utilize third parties to translate your data and/or imagery to facilitate communication across different languages.";
try {
if (!document.getElementById("tr-msz-" + value)) {
var tr_para = document.createElement("P");
tr_para.setAttribute("id", "tr-msz-" + value);
tr_para.setAttribute("class", "tr-msz");
tr_para.style.textAlign = 'justify';
var tr_fTag = document.createElement("IMG");
tr_fTag.setAttribute("class", "tFlag");
tr_fTag.setAttribute("src", "/html/assets/langTrFlag.PNG");
tr_fTag.style.marginRight = "5px";
tr_fTag.style.height = "14px";
tr_para.appendChild(tr_fTag);
var tr_textNode = document.createTextNode(tr_text);
tr_para.appendChild(tr_textNode);
/* Woot message only for multi source */
if(rootElement.querySelector(".lia-quilt-forum-message")){
rootElement.querySelector(".lia-quilt-forum-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-message-view-blog-topic-message")) {
rootElement.querySelector(".lia-message-view-blog-topic-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-blog-reply-message")){
rootElement.querySelector(".lia-quilt-blog-reply-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-message")){
rootElement.querySelector(".lia-quilt-tkb-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-reply-message")){
rootElement.querySelector(".lia-quilt-tkb-reply-message").insertBefore(tr_para,rootElement.querySelector(".lia-quilt-row.lia-quilt-row-footer"));
} else if(rootElement.querySelector(".lia-quilt-idea-message")){
rootElement.querySelector(".lia-quilt-idea-message").appendChild(tr_para);
} else if(rootElement.querySelector('.lia-quilt-occasion-message')){
rootElement.querySelector('.lia-quilt-occasion-message').appendChild(tr_para);
else {
if (rootElement.querySelectorAll('div.lia-quilt-row-footer').length > 0) {
rootElement.querySelectorAll('div.lia-quilt-row-footer')[0].appendChild(tr_para);
} else {
rootElement.querySelectorAll('div.lia-quilt-column-message-footer')[0].appendChild(tr_para);
} catch (e) {
} else {
/* Do not display button for same language */
// syncList.remove(value);
var index = $scope.syncList.indexOf(value);
if (index > -1) {
$scope.syncList.splice(index, 1);
/* V 1.1:2 = Reply Sync button for multi source translation */
} catch(e){
console.log(e);
if((rContent != undefined) && (rContent != "")) {
drawCanvas(decodeURIComponent(rContent));
/** Update variable with selected language code **/
$scope.previousSelCode = code_l;
* @function manageTranslation
* @description Managess the translation of given language for the thread
* @param {string} langCode - Language Code
* @param {string} tid - Thread ID
$scope.manageTranslation = function (langCode, tid) {
//debugger;
$scope.showTrText = false;
/* V 2.0:5 = actualStatus variable introduced to indicate detailed connector status on UI. This variable holds the actual translation percentage */
$scope.transPercent = "";
$scope.actualStatus = "";
if (tid != "") {
var bulkTranslation = lithiumPlugin.bulkTranslation(langCode, tid);
bulkTranslation.then(function (trContent) {
if(trContent.body != "") {
$scope.showPreview(trContent.body, $scope.mszList, langCode);
if(langCode != "en-US") {
$scope.showTrText = true;
if((trContent.status != "NA") && trContent.status != null) {
// $scope.transPercent = String(trContent.status);
$scope.actualStatus = String(trContent.status);
} else {
// $rootScope.errorMsg = "Translation is in progress. Please check again a few minutes."
$rootScope.errorMsg = "Translation is in progress. Please retry in a few minutes."
$scope.workbench = trContent.wb;
/* V 2.0:4 = Trigger uncalled or delayed callbacks (documnet uploaded/translation completed from lithium).*/
if(trContent.callback == 'true') {
var trCompletCallback = lithiumPlugin.trCompletCallback(langCode, trContent.docID);
trCompletCallback.then(function (callback){
// $rootScope.errorMsg = "Downloading Translated content in " + langCode + " now. Please check again in a few minutes."
$rootScope.errorMsg = "Uploading content to translate. Please check again in a few minutes."
} else if (trContent.callback == 'upload') {
var trCompletUpload = lithiumPlugin.trCompletUpload(langCode, trContent.docID);
trCompletUpload.then(function (callback) {
//$rootScope.errorMsg = "Uploading content to translate. Please check again in a few minutes."
} else if ("many" == "one") {
$scope.updateOOS();
} else if("SmartConx" == "SmartConx"){
if ("many" == "many"){
$scope.updateOOS();
}else if ((trContent.status != null) && trContent.status.includes("100")) {
/* If everything fine then only check Out of Sync status */
$scope.updateOOS();
} else {
/* If translation perccent is less than 100 then show the percentage on UI */
$scope.transPercent = $scope.actualStatus;
* @function selectThisLang
* @description Called on select dropdown.
* @param {string} lang - Language code
$scope.selectThisLang = function (lang, anonymousFlag) {
/* 1.4:3 Update Analytics on language selection */
try {
lingoThreadLangSelected(lang, '753676');
} catch (e) {
/** Display Translated content **/
var getTranslation = lithiumPlugin.getTranslation(lang, "753676");
getTranslation.then(function (trContent) {
if (trContent.body != "") {
$scope.showPreview(trContent.body, $scope.mszList, lang);
} else {
//$rootScope.errorMsg = "Translation is in progress. Please check again in a few minutes."
var decodeEntities = (function() {
// this prevents any overhead from creating the object each time
var element = document.createElement('div');
function decodeHTMLEntities (str) {
if(str && typeof str === 'string') {
// strip script/html tags
str = str.replace(/
