Connect a tool embedded in a Windows Form
1280
08-16-2012 06:46 AM
GorkemTolan
I'm trying to get x and y coordinates from the map when I click it. The mousedown event is initialized by the button(tool) which is embedded in a windows form. The windows form resides in the ArcMap application. The problem is initializing (activating) the mouse down event by the windows button. Any suggestions would be great.
Here is the windows button click event:
Private Sub btnMapSelection_Click(sender As System.Object, e As System.EventArgs) Handles btnMapSelection.Click
        Dim pTool As New CoordinateSelectorTool
        pTool.OnCreate(_application)
        pTool.SetForm(Me)
        Me.Hide()
        Dim UIDCls As ESRI.ArcGIS.esriSystem.IUID = New ESRI.ArcGIS.esriSystem.UIDClass
        UIDCls.Value = "CTM.GIS.GISDesktop.CoordinateSelectorTool"
        Dim commandItem As ESRI.ArcGIS.Framework.ICommandItem = _application.Document.CommandBars.Find(UIDCls)
        If commandItem Is Nothing Then
            Exit Sub
        End If
        _application.CurrentTool = commandItem
        '_application.CurrentTool = GetCommandItem("{94ea5994-2e62-44b7-8786-a0d0075e91e8}")
    End Sub
ArcObject Tool:
Public Overrides Sub OnMouseDown(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Integer, ByVal Y As Integer)
        Dim pMxDoc As IMxDocument
        pMxDoc = m_application.Document
        ClickPoint = pMxDoc.ActiveView.ScreenDisplay.DisplayTransformation.ToMapPoint(X, Y)
        'TODO: Add CoordinateSelectorTool.OnMouseDown implementation
    End Sub
KenBuja
MVP Esteemed Contributor
This is how I've done it in one of my applications, a Desktop Add-in
The code in my window that contains several drawing options...a buffered point, a polygon, a rectangle, etc. I have another class DrawTool that handles the OnMouseDown action
   Private Sub Draw_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnPoint.Click, btnPolygon.Click, btnFreehand.Click, btnRectangle.Click
        Dim pUID As New ESRI.ArcGIS.esriSystem.UID
        Dim pCommandItem As ESRI.ArcGIS.Framework.ICommandItem
        Try
            pUID.Value = My.ThisAddIn.IDs.DrawTool
            pCommandItem = m_application.Document.CommandBars.Find(pUID, False, False)
            Select Case sender.name
                Case "btnPoint"
                    'this contains code for specific actions for the point button
                Case "btnFreehand"
                     'this contains code for specific actions for the freehand button
            End Select
            Me.Visible = False
            m_application.CurrentTool = pCommandItem
        Catch ex As Exception
            System.Windows.Forms.MessageBox.Show(ex.ToString, "Open Draw Feature")
        End Try
    End Sub
This is the DrawTool class
Public Class DrawTool
    Inherits ESRI.ArcGIS.Desktop.AddIns.Tool
    Private graphicsContainer As ESRI.ArcGIS.Carto.IGraphicsContainer
    Private m_LineFeedback As ESRI.ArcGIS.Display.INewBezierCurveFeedback = Nothing
    Protected Overrides Sub OnMouseDown(ByVal arg As ESRI.ArcGIS.Desktop.AddIns.Tool.MouseEventArgs)
        MyBase.OnMouseDown(arg)
        Try
            Dim activeView As ESRI.ArcGIS.Carto.IActiveView = My.ArcMap.Document.ActiveView
            Dim pGeometry As ESRI.ArcGIS.Geometry.IGeometry5 = GetFeatureFromMouse(activeView, arg.X, arg.Y)
            Dim rgbColor As ESRI.ArcGIS.Display.IRgbColor = New ESRI.ArcGIS.Display.RgbColorClass()
            Dim FillStyle As ESRI.ArcGIS.Display.esriSimpleFillStyle
            rgbColor.Red = 255
            FillStyle = ESRI.ArcGIS.Display.esriSimpleFillStyle.esriSFSBackwardDiagonal
            If pGeometry Is Nothing Then Exit Sub
           AddGraphicToMap(pGeometry, rgbColor, rgbColor, FillStyle) 'this is the ArcGIS snippet "Add Graphic to Map"
            System.Windows.Forms.MessageBox.Show(ex.ToString)
        Finally
            m_DrawFeature.Visible = True 'This is the form with the buttons
        End Try
    End Sub
    Public Function GetFeatureFromMouse(activeView As ESRI.ArcGIS.Carto.IActiveView, XVal As Integer, YVal As Integer) As ESRI.ArcGIS.Geometry.IGeometry5
        Dim screenDisplay As ESRI.ArcGIS.Display.IScreenDisplay = activeView.ScreenDisplay
        Dim pRubberBand As ESRI.ArcGIS.Display.IRubberBand2
        Dim pPoint As ESRI.ArcGIS.Geometry.IPoint
        Dim pPolygon As ESRI.ArcGIS.Geometry.IPolygon4
        Dim pPolyLine As ESRI.ArcGIS.Geometry.IPolyline6
        Try
            Select Case Globals.DrawFeatureType
                Case "Point"
                    pRubberBand = New ESRI.ArcGIS.Display.RubberPoint
                    pPoint = pRubberBand.TrackNew(screenDisplay, Nothing)
                    Return pPoint
                Case "Polygon"
                    pRubberBand = New ESRI.ArcGIS.Display.RubberPolygon
                    pPolygon = pRubberBand.TrackNew(screenDisplay, Nothing)
                    Return pPolygon
                Case "Rectangle"
                    pRubberBand = New ESRI.ArcGIS.Display.RubberEnvelope
                    pGeometry = pRubberBand.TrackNew(screenDisplay, Nothing)
                    Return pGeometry
                Case "Freehand"
                    pPoint = activeView.ScreenDisplay.DisplayTransformation.ToMapPoint(XVal, YVal)
                    If m_LineFeedback Is Nothing Then
                        m_LineFeedback = New ESRI.ArcGIS.Display.NewBezierCurveFeedback
                        m_LineFeedback.Display = screenDisplay
                        m_LineFeedback.Start(pPoint)
                        Return Nothing
                    Else
                        pPolyLine = m_LineFeedback.Stop
                        m_LineFeedback = Nothing
                        pPolygon = CreatePolygonfromPolyline(pPolyLine)
                        Return pPolygon
                    End If
                Case Else
                    System.Windows.Forms.MessageBox.Show("Not coded yet")
                    Return Nothing
            End Select
            System.Windows.Forms.MessageBox.Show(ex.ToString, "Get Feature")
            Return Nothing
        End Try
    End Function
    Private Function CreatePolygonfromPolyline(pPolyline As ESRI.ArcGIS.Geometry.IPolyline6) As ESRI.ArcGIS.Geometry.IPolygon4
        Try
            Dim pOutCollection As ESRI.ArcGIS.Geometry.IPointCollection4 = New ESRI.ArcGIS.Geometry.Polygon
            pOutCollection.AddPointCollection(pPolyline)
            pPolygon = pOutCollection
            pPolygon.Close()
            Return pPolygon
            System.Windows.Forms.MessageBox.Show(ex.ToString, "Conversion error")
            Return Nothing
        End Try
    End Function
GorkemTolan
Ken,
thank you for your answer. My tool is not add-in in ArcMap. Thus I can't get a reference to the tool.
commandItem returns nothing. Therefore, I can not assign it to the application's current tool. Maybe I am missing something.
KenBuja
Have you tried using the actual GUID of your tool instead? As I understand, the tool has to be on a tollbar or menu somewhere to use the ProgID (CTM.GIS.GISDesktop.CoordinateSelectorTool)
UIDCls.Value =  "{" & yourClass.ClassId & "}"
GorkemTolan
Yes I tried with the classID and progID. Application can not find the tool.
Here is the tool cool. It's very generic. I think I don't register the class somewhere. Thanks,
Imports System.Runtime.InteropServices
Imports System.Drawing
Imports ESRI.ArcGIS.ADF.BaseClasses
Imports ESRI.ArcGIS.ADF.CATIDs
Imports ESRI.ArcGIS.Framework
Imports ESRI.ArcGIS.ArcMapUI
Imports System.Windows.Forms
Imports ESRI.ArcGIS.Geometry
Imports ESRI.ArcGIS.SystemUI
<ComClass(CoordinateSelectorTool.ClassId, CoordinateSelectorTool.InterfaceId, CoordinateSelectorTool.EventsId), _
 ProgId("CTM.GIS.GISDesktop.CoordinateSelectorTool")> _
Public NotInheritable Class CoordinateSelectorTool
    Inherits BaseTool
    Implements ICommand
#Region "COM GUIDs"
    ' These  GUIDs provide the COM identity for this class
    ' and its COM interfaces. If you change them, existing
    ' clients will no longer be able to access the class.
    Public Const ClassId As String = "94ea5994-2e62-44b7-8786-a0d0075e91e8"
    Public Const InterfaceId As String = "f0bad365-71c4-4e83-ab96-54d6f0f0e904"
    Public Const EventsId As String = "8899000e-aa7c-424e-a34a-38ab47c9cc79"
#End Region
#Region "COM Registration Function(s)"
    <ComRegisterFunction(), ComVisibleAttribute(False)> _
    Public Shared Sub RegisterFunction(ByVal registerType As Type)
        ' Required for ArcGIS Component Category Registrar support
        ArcGISCategoryRegistration(registerType)
        'Add any COM registration code after the ArcGISCategoryRegistration() call
    End Sub
    <ComUnregisterFunction(), ComVisibleAttribute(False)> _
    Public Shared Sub UnregisterFunction(ByVal registerType As Type)
        ArcGISCategoryUnregistration(registerType)
        'Add any COM unregistration code after the ArcGISCategoryUnregistration() call
    End Sub
#Region "ArcGIS Component Category Registrar generated code"
    Private Shared Sub ArcGISCategoryRegistration(ByVal registerType As Type)
        Dim regKey As String = String.Format("HKEY_CLASSES_ROOT\CLSID\{{{0}}}", registerType.GUID)
        MxCommands.Register(regKey)
    End Sub
    Private Shared Sub ArcGISCategoryUnregistration(ByVal registerType As Type)
        MxCommands.Unregister(regKey)
    End Sub
#End Region
#End Region
    Public m_application As IApplication
    Public ClickPoint As IPoint
    Public ReturnForm As System.Windows.Forms.Form
    Public _arcmap As IMxDocument
    Public myExt As ESRI.ArcGIS.esriSystem.IExtension
    ' A creatable COM class must have a Public Sub New()
    ' with no parameters, otherwise, the class will not be
    ' registered in the COM registry and cannot be created
    ' via CreateObject.
    Public Sub New()
        MyBase.New()
        ' TODO: Define values for the public properties
        MyBase.m_category = ""  'localizable text
        MyBase.m_caption = ""   'localizable text
        MyBase.m_message = ""   'localizable text
        MyBase.m_toolTip = "" 'localizable text
        MyBase.m_name = ""  'unique id, non-localizable (e.g. "MyCategory_ArcMapTool")
        Try
            'TODO: change resource name if necessary
            Dim bitmapResourceName As String = Me.GetType().Name + ".bmp"
            MyBase.m_bitmap = New Bitmap(Me.GetType(), bitmapResourceName)
            MyBase.m_cursor = New System.Windows.Forms.Cursor(Me.GetType(), Me.GetType().Name + ".cur")
            'Dim document As IDocument = CType(_arcmap.CurrentDocument, IDocument)
            'm_application = document.Parent
            OnClick()
            System.Diagnostics.Trace.WriteLine(ex.Message, "Invalid Bitmap")
        End Try
    End Sub
    Public Overrides Sub OnCreate(ByVal hook As Object)
        If Not hook Is Nothing Then
            m_application = CType(hook, IApplication)
            _arcmap = m_application.Document
            CoordinateSelectorTool.ArcGISCategoryRegistration(Me.GetType())
            CoordinateSelectorTool.RegisterFunction(Me.GetType())
            'Disable if it is not ArcMap
            If TypeOf hook Is IMxApplication Then
                MyBase.m_enabled = True
                Me.OnClick()
                myExt = m_application.FindExtensionByName("CTM.GIS.GISDesktop.CoordinateSelectorTool")
            Else
                MyBase.m_enabled = False
            End If
        End If
        ' TODO:  Add other initialization code
    End Sub
    Public Overrides Sub OnClick()
        'TODO: Add CoordinateSelectorTool.OnClick implementation
    End Sub
    End Sub
    Public Overrides Sub OnMouseMove(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Integer, ByVal Y As Integer)
        'TODO: Add CoordinateSelectorTool.OnMouseMove implementation
    End Sub
    Public Overrides Sub OnMouseUp(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Integer, ByVal Y As Integer)
        'TODO: Add CoordinateSelectorTool.OnMouseUp implementation
    End Sub
    Public Sub SetForm(m_form As System.Windows.Forms.Form)
        If (m_form IsNot Nothing) Then
            ReturnForm = m_form
        End If
    End Sub
    Protected Sub ShowForm()
        If (ReturnForm IsNot Nothing) Then
            ReturnForm.Show()
        End If
    End Sub
End Class
