Using a 10.0 .NET SQL Server security store in 10.1
4766
9
08-10-2012 11:05 AM
SimonRoss_User
We're trying to connect to our previous 10.0 Security Store following the instructions here
http://resources.arcgis.com/en/help/main/10.1/index.html#/Using_a_10_0_NET_SQL_Server_security_store...
We've moved the sql database onto the same machine running Server 10.1 and the natemtping to change the identitstore connection. Have tried multiple permutations of the JSON strings proposed on the help page but keep geting the same error message every time for which I find no reference in the help
The connection name 'SQLConnString' was not found in the applications configuration or the connection string is empty.
Can someone confirm whether they've had success with this connection syntax?
What is the correct syntax for a locally hosted SQL instance?
Any specific permissions that need to be granted on the database (e.g. which users should have access)?
any help appreciated
Simon
SimonRoss_User
http://support.esri.com/en/bugs/nimbus/TklNMDgwODM2
1. Stop the ArcGIS Server service
2. Copy 'javaw.exe.config' from : C:\Program Files\ArcGIS\server\framework\runtime\jre\bin\
3. Paste into: C:\Program Files\ArcGIS\server\bin
4. Rename 'javaw.exe.config' to 'ArcSOC.exe.config'
5. Start ArcGIS Server service.
It should now work.
That does work (as ESRI support managed to tell me about an hour before you did!).  Unfortunately we still experienced another error after making this change.  Specifally covered by another bug with another workaround
http://support.esri.com/en/bugs/nimbus/role/beta10_1/TklNMDgxMjI1
good news is that both bugs are fixed at 10.1 SP1
If you still have issues you should be aware of a third bug that shows the connection is successful when it isn't.  Unfortunately I can't find the reference for the quoted bug NIM084058
Thanks for support from all
BubbaHey
Other people have been having same problem. I think there is an error in the documentation.
SimonRoss_User
Glad to hear I'm not the only one. I'm working through it with ESRI support at the moment and will post a resolution when we find one.
Cheers
Simon
PeterMcDaid
It should now work.
MarkWells
This is a bug, which according to its status will be fixed in SP1.
Until SP1 is released you can perform this workaround:
SimonRoss_User
It should now work.
danbecker
was able to get 'connection successful' after c/p the file mentioned above, and I can view the roles in /manager, but I cannot view users? the loading bar just spins.
Is this the bug 'successful connection' when the string is actually wrong?
SimonRoss_User
No, this is this bug
danbecker
can you post the bug number? for some reason I can't login to the above link, i get the revolving login screen. thanks!
SimonRoss_User
Bug number for user page hanging is NIM081225
