ArcGIS for Server 10.1 failed to connect to Window Domain/LDAP as user store
2858
5
08-17-2012 06:49 AM
fuliaoli
We installed the server on Windows 2008 R2 with a domain user. Installation went ok, but when we tried to use either Window Domain or LDAP as user/role store, errors occurred:
Test connection failed.
[LDAP: error code 8 - 00002028: LdapErr: DSID-0C0901FC, comment: The server requires binds to turn on integrity checking if SSL\TLS are not already active on the connection, data 0, v1db1]
We tried to use another tool to connect to our LDAP:636 and it was ok.
My questions is what the ArcGIS Server host settings and the domain server settings should be set for the two to communicate?
We haven't found any detailed about that.
Thanks in advance,
Regards,
li
BubbaHey
BubbaHey
Here's another link:
Securing services with users and roles from an LDAP server
http://resources.arcgis.com/en/help/main/10.1/index.html#//01540000050w000000
fuliaoli
Thanks a lot!
How did you find those? That will give us some ammunitions to tackle the problem with.
I'll have to wait until our domain admin comes in next week. I'll let you know the result.
You have a good day.
li
BubbaHey
Welcome. When I searched on ESRI's support site, I didn't find much, but just a Google search of   ArCGIS security 10.1 ldap brought up a lot of links.
fuliaoli
Somehow we are still unable to use Window Domain/LDAP as user store. Our network support opens a ticket with Esri to see how that goes. Thanks.
