Get Value of joined fields
971
08-09-2012 03:20 AM
MichaelBreitfeld
how get the value of joined attributtes like
string valueCode = m_currentFeature.get_Value(indexField).ToString();
the index of specific joined field in FeatureClass i get with
        public static int FindAttributeIndexWithJoinedFields(frmKarte form, string layerName, string attributName)
            IFeatureLayer actFeatLyr = (IFeatureLayer)form.axMapControl1.Map.GetLayerByName(layerName);
            ILayerFields fields = (ILayerFields)actFeatLyr;
            return fields.FindField(attributName);
Can you help me, please?
Thank you!
JamesCrandall
Thank you!
Use IDisplayTable when working with Joins.
MichaelBreitfeld
Hi jamesfreddyc
                IDisplayTable dispTable = (IDisplayTable)actFeatLyr;
                ITable table = dispTable.DisplayTable;
                IRow row = table.GetRow(feature.OID);
                Debug.Print(row.get_Value(index).ToString());
Thanks you!
Perfect!
JamesCrandall
Hi jamesfreddyc
Thanks you!
Perfect!
Excellent.
If you mark as answered then it will benefit others who are searching on this topic 😉
