Any way to check whether a COM ArcObjects object is already released?
3826
12
08-02-2012 10:02 AM
SuiHuang
Hi Everybody:
    I found that after an ArcObject COM object is release, some operations such as checking interface cannot be performed on it and otherwise it will throw exception.
    Is there any way for me to detect whether the object has already been release? I am trying not to use the TRY-CATCH pair to handle this logic...
    Thank you.
**************** Released twice by my utility function ******
    IPoint obj = new PointClass();
    ReleaseObjects(obj);
**************** Utility functions *********
        public void ReleaseObjects(params object[] comObjList)
            foreach (object obj in comObjList)
                if (obj != null)
                    if (obj is System.Collections.IEnumerable)
                        ReleaseComs(obj as IEnumerable);
                    else
                        Marshal.ReleaseComObject(obj);
        private void ReleaseComs(IEnumerable Objects)
            foreach (object obj in Objects)
                if (obj != null)
                    if (obj is IEnumerable)
                    else
AlexanderGray
Honored Contributor
Using releaseComObject is necessary in .NET code because some objects' reference count don't decrement when they go out of scope and don't get collected in GarbageCollection.  This is a problem for cursor because you can exceed the number of open cursors you are allowed to have.  It is also a problem with featureclasses and workspaces and other geodatabase objects that maintain locks until they are explicitly release.
If you set your variable to null after calling the release you should be able to test to see if the variable is null and avoid calling it a second time.  Aside from that I would only suggest keeping a tighter control on the variables to avoid release being called a an object separated from the RCW.
LeoDonahue
What are you trying to do?
If .NET Garbage collection works the same way as it does in Java, then when an object variable goes out scope, or you set it to null or you assign it another reference, then the object becomes eligible for garbage collection, but you don't know when exactly that happens in the run time environment.
Personally, I don't think you should care whether it has been released or not after the fact, because you would be the person who is releasing it intentionally or via the the way you are structuring your code.
Maybe this link describes what you want to do:  http://edndoc.esri.com/arcobjects/9.2/NET/fe9f7423-2100-4c70-8bd6-f4f16d5ce8c0.htm#ReleaseComObject
AlexanderGray
Honored Contributor
SuiHuang
[/url]
Just because I am releasing it intentionally, I need to care. Because the current way I am structuring the code doesn't support double releasing. Releasing a released COM object will throw exception.
SuiHuang
Thank you! Seems then assigning null value and avoid calling a second time are the only available ways to go.
LeoDonahue
If you, as the programmer, decided to release an object reference, why do you want to know if it has been released or not?  Create a new object.
LeoDonahue
Not to nitpick, but if you set a reference to null *after* you have explicitly released it, what other value do you expect it to have when you test it for null?
Is Sui trying to call a method on that Object just before it is actually killed off?  Not a good idea.
SuiHuang
Not to nitpick, but if you set a reference to null *after* you have explicitly released it, what other value to expect it to have when you test it for null?
Here is a sample senario:
List<IFeature> fList = ...
int i = ...
IFeature f = null;
if (...)
    f = fList
else if
    f=...
//release fList
//release f
In the above case if I release everything in fList without assigning null and f=fList was executed, then I will get exception.
LeoDonahue
If you are releasing fList and f at the end of your procedure/function/method - whatever, how are you getting an exception?
Also, telling us what kind of exception you're getting would help.  Is it NullPointerException?  AutomationException?  something else?
SuiHuang
Hi Idonahue:
    The exception message tells "COM object that has been separated from its underlying RCW cannot be used."
    Any idea? Thank you!
