It does not work when using jsapi_vsdoc_v3,but works without jsapi_vsdoc_v3,help
1201
08-07-2012 11:02 PM
gaolei
I has test arcgis_js_api v3 for studying,the test code comes from the instruction "install.html" .
When I don't use "jsapi_vsdoc_v3", there is no intelligent code tip,but the html showed in Explorer collectly.
When I use "jsapi_vsdoc_v3",like add "<script type="text/javascript" src="assets/jsapi_vsdoc_v3.js"></script>" in my test html,
the intelligent code tip does work, but when I see the html in Explorer, the map doesn't showed (although it doesn't say error).
I don't know what's the matter.
JohnGravois
I did a quick test and confirmed that basemaps definitely still display in Internet Explorer when the code assist is referenced with a script tag in an application.
I used the following sample as the basis of the application and added my script tag directly below the tag referencing our API on line 21. (see below)
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/map_topo.html
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script>
 <script type="text/javascript" src="Assets/scripts/jsapi_vsdoc_v3.js"></script>
    <script type="text/javascript">
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
Where did you get this "install.html" file?
what is the URL of the basemap which is not displaying?
Where are you placing the script tag in your application?
gaolei
thank you for your reply!
I has downloaded the lastest zip for jsapiv3.1 and it's Ok.
thank you.
