Installing the ArcGIS JavaScript 3.1 API library on an IIS Web Server
2240
5
08-06-2012 03:46 PM
SharathNarasimhan
Is there an updated installation manual for local deployment of ArcGIS JavaScript 3.1 API library ? The following instructions in the manual appear to be no longer valid:
Configuration options for normal build:
Open C:\Inetpub\wwwroot\arcgis_js_api\library\3.1\jsapi\init.js in a text editor and search for the text '[HOSTNAME_AND_PATH_TO_JSAPI]', and replace this text with "<myserver>/arcgis_js_api/library/3.1/jsapi/"
Open C:\Inetpub\wwwroot\arcgis_js_api\library\3.1\jsapi\js\dojo\dojo\dojo.js in a text editor and search for the text '[HOSTNAME_AND_PATH_TO_JSAPI]', and replace this text with "<myserver>/arcgis_js_api/library/3.1/jsapi/"
Open C:\Inetpub\wwwroot\arcgis_js_api\library\3.1\jsapi\js\dojo\dojo\dojo.js.uncompressed.js in a text editor and search for the text '[HOSTNAME_AND_PATH_TO_JSAPI]', and replace this text with "<myserver>/arcgis_js_api/library/3.1/jsapi/"
Please help me out in this regard.
gaolei
I found the text in v3.0 is "[HOSTNAME_AND_PATH_TO_JSAPI]js/dojo/dojo",
but in v3.1 is "serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dojo",maybe the newly instruction hasn't updated.
I can't find "dojo.js.uncompressed.js " in v3.1, and I found the file v3.1 is 15MB,but v3.0 is 26MB, any error?
SharathNarasimhan
Well yes, there is no "dojo.js.uncompressed.js " in v3.1. I get an error saying dojo is undefined, since the http://<my_server>/arcgis_js_api/library/3.1/jsapi/?v=3.1" is not accessible. (Because there is no default.ashx / index.jsp files ?)
__Rich_
Looks like someone forgot to include the handlers in the zip, unless something radical has changed, the ones from v3.0 should be fine.
@Sharath - default.ashx is the one for you, place the file under the jsapi directory (or jsapicompact if you're using the compact build) then set the default document in IIS for that directory.
HTH
P.S. this is pretty poor, especially since additionally, as correctly observed above, the instructions are invalid i.e. the [HOSTNAME_AND_PATH_TO_JSAPI] strings aren't present.
P.P.S. You can avoid this (URL replacement) step anyway if you correctly set the baseUrl up-front.
JanJeske
To install it u have to replace 'serverapi.arcgisonline.com' with your path.
as example you have then
yourserver.de/jsapi/arcgis/3.1/js/dojo/dojo
yourserver.de/libraries/jsapi/3.1/jsapicompact/js/dojo/dojo
this should be made in the files init.js and js/dojo/dojo/dojo.js
to include the jsapi include 'yourserver.de/libraries/jsapi/3.1/jsapicompact/init.js' or if you want to do it like the other versions < 3.1
create a file you want
for php:
<?php
header("Content-type:application/x-javascript");
readfile("js/dojo/dojo/dojo.js");
readfile("js/esri/jsapi.js");
for .net:
<%@ WebHandler Language="C#" Class="jsapi" %>
using System;
using System.Web;
using System.IO;
public class jsapi : IHttpHandler {
  public void ProcessRequest (HttpContext context) {
    // GZIP if supported
    string AcceptEncoding = HttpContext.Current.Request.Headers["Accept-Encoding"];
    if (!string.IsNullOrEmpty(AcceptEncoding) && AcceptEncoding.Contains("gzip")) {
      context.Response.AppendHeader("Content-Encoding", "gzip");
      context.Response.Filter = new System.IO.Compression.GZipStream(context.Response.Filter, System.IO.Compression.CompressionMode.Compress);
    context.Response.ContentType = "application/x-javascript";
    context.Response.Expires = 1800;
    context.Response.WriteFile(context.Server.MapPath("js\\dojo\\dojo\\dojo.js"));
    context.Response.WriteFile(context.Server.MapPath("js\\esri\\jsapi.js"));
  public bool IsReusable {
    get {
      return false;
or for JSP:
<%@page contentType="application/x-javascript; charset=utf-8" session="false" %>
<jsp:include page="js/dojo/dojo/dojo.js" />
<jsp:include page="js/esri/jsapi.js" />
save your createt file and set it as default for that path.
Now you can call the jsapi 'yourserver.de/libraries/jsapi/3.1/jsapicompact/'
SharathNarasimhan
Thanks for the replies. Adding the web handler and replacing the URLs in files init.js and dojo.js seems to work for me.
