about location problem
1233
07-25-2012 02:17 AM
lujun
i have encountered a problem
java code below
Graphic graphic = new Graphic(mMapView.toMapPoint(new Point(x,y))
      ,new SimpleMarkerSymbol(Color.RED,25,STYLE.CIRCLE));
    mGraphicsLayer.addGraphic(graphic);
in the code, parameter x and y are passed from Server side.I don't know why the graphic could not display on the map view
deleted-user-ATjHIWsdQYmT
java code below
mMapView.toMapPoint() converts screen coordinates to map coordinates.  I imagine your x/y's are in real-world coords, not in screen coords, correct?
try removing mMapView.toMapPoint and just using:
Graphic graphic = new Graphic(new Point(x,y)
Also, make sure your x/y points are in the same coordinate space as your map.
lujun
yeah,that's the key ,thanks
i am new ,thanks for figuring the method toMapPoint out
