creating proxy page - arcgis for JS samples
1111
07-23-2012 03:49 AM
MostafaFouly
i am not quite sure if i should post this thread under ArcGIS API for JS or not, but since the sample that i am referring to is under this topic so i decided posting it here.
i've been trying to adapt the "Attribute Editing" (under Mobile folder) sample on my machine, so as to host it locally and not over esri server.
i had to create a proxy page as as mentioned in the sample documentation:
//This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to
//replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
//for details on setting up a proxy page.
the proxy page was created (below the proxy.config file):
<?xml version="1.0" encoding="utf-8" ?>
<!-- Proxy config is used to set the ArcGIS Server services that the proxy will forward to.
        mustMatch: true to only proxy to sites listed, false to proxy to any site -->
<ProxyConfig mustMatch="true">
  <serverUrls>
    <!-- serverUrl options:
            url = location of the ArcGIS Server, either specific URL or stem
            matchAll = true to forward any request beginning with the url
            token = (optional) token to include for secured service
            dynamicToken = if true, gets token dynamically with username and
              password stored in web.config file's appSettings section.
<serverUrl url="http://sampleserver5.arcgisonline.com/ArcGIS/rest/services/"
     matchAll="true"></serverUrl>
    <serverUrl url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/"
    <serverUrl url="http://server.arcgisonline.com/arcgis/rest/services/"
<serverUrl url="http://serverapi.arcgisonline.com"
  </serverUrls>
</ProxyConfig>
note: i put the .html file, the .ashx file and the .config file in the same website folder.
but i still get an error when trying to add an issue, does anybody faces the same issue? somebody can help to find out what the problem is?
thx!
mostafa.
MostafaFouly
just to make it more clear, i allowed the POST request over IIS 7.5 by adding Module Mapping, so the error isn't related to the POST request
