Measurement Widget and compact API
1539
07-19-2012 09:12 AM
DarellStoick
I am trying to use the ...?v=3.0compact and the Measurement Widget.  It doesn't appear the compact version of the API has everything the widget requires but it should be possible to add the missing references with dojo.require().
Any one know which ones I need to add in order to get the Measurement widget to work?
thanks
MattLane
The measurement widget requires dojo.number.
MattLane
JianHuang
When you call dojo.require("esri.dijit.Measurement"), it should include all the required module automatically. So you don't have to call those requires again.
Just for your information, here is the list of the required.
dojo.require("dijit._Widget");
dojo.require("dijit._Templated");
dojo.require("esri.map");
dojo.require("esri.geometry");
dojo.require("esri.symbol");
dojo.require("dojo.parser");
dojo.require("dijit.layout.ContentPane");
dojo.require("dijit.Menu");
dojo.require("dijit.form.Button");
dojo.require("esri.tasks.geometry");
dojo.require("esri.WKIDUnitConversion");
DarellStoick
using the Resource Center sample under Widget ->Measurement
If I replace
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.0"></script>
with
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.0compact"></script>
I get an error in the measurement.js script file when I use the Area or Distance tools.  Coordinates seems to work. Running with ...3.0 works fine.
I'll try to add the references you supplied and see if it works w/ compact
DarellStoick
Adding dojo.require("dojo.number"); is what I needed - Thanks
