Adding multiple rasters together using python
6617
7
07-18-2012 06:58 AM
ClaireParsons
I have a number of raster datasets in a folder that I want to sum/add together.
I'm having trouble doing this - I've created a raster list but the output doesn't seem to be adding them together.
Can someone help please.
import arcpy, os
from arcpy import env
from arcpy.sa import *
env.workspace = r"C:\Users\Documents\GIS\Site Selection Example\Output Datasets\Cons_Raster"
rasterList  = arcpy.ListRasters("*")
for raster in rasterList:
    print raster
    # Execute CellStatistics
    outCellStatistics = CellStatistics(raster, "SUM", "NODATA")
    # Save the output
    outCellStatistics.save("C:/data/sumRast.tif")
thanks Claire
PhilMorefield
You don't need to iterate through each raster in your list. You just need to provide the tool with the list of rasters one time, and it will add them together.
import arcpy, os
print rasterList
outCellStatistics = CellStatistics(rasterList, "SUM", "NODATA")
# Save the output
ClaireParsons
Hi Phil
thanks for your reply - this still isn't working - the output is a fraction of the size it should be (See attached) - it even does this when I use the tool in ArcMap but I do get a larger area.
Help would be much appreciated as I have to get this piece of work delivered tomorrow.
thanks
Claire
PhilMorefield
I don't think the image you tried to attach is showing up. There are few things I would check. First, make sure all of your rasters have the same extent and projection. If any part of any raster has no data, your output for that cell will have no data. You could also set the processing extent to the union on all inputs, just to be thorough.
I'm assuming you checked the value for 'rasterList' and all of the file names or included and look okay? As a matter of best practice, you shouldn't have spaces or special characters in file names or paths; you currently have some spaces in your folder names.
SteveLynch
You need to set the output extent = max of the input rasters
Steve
AndrewOrr
I just did the procedure Phil provided and it worked well for me. However, why on earth can you not iterate through a list of rasters and have each one add together? I spent a good 10 hours trying to figure out why this would not work. Seems to me a very stupid limitation since this works for multiple other tools where you can iterate through lists of files.
-Andy
PhilMorefield
-Andy
You can, it just isn't as clean:
import arcpy, os
arcpy.env.workspace = r"C:\Users\Documents\GIS\Site Selection Example\Output Datasets\Cons_Raster"
print rasterList
sumEmpty = 'Yes'
for rasName in RasterList:
    rasObject = arcpy.Raster(rasName)
    if sumEmpty == 'Yes':
        sumRas = rasObject
        sumEmpty = 'No'
    else:
        sumRas = sumRas + rasObject
# Save the output
sumRas.save("C:/data/sumRas.tif")
AndrewOrr
Thanks Phil! I guess my issue was trying to convert the names into Raster objects within the actual "raster calculator" equation itself. I don't have the exact code I was using, but it was something on the order of:
yell_rasterList = arcpy.ListRasters("*")
for raster in yell_rasterList:
     sumRasters = Raster("constantRas") + Raster(raster)
sumRasters.save("SumRaster")
That's probably not the correct syntax for what I had used, but I think it gets the idea across. I was getting an error saying that I couldn't convert an object to a raster or something like that.
Either way, I'm glad the cellStatistics method worked out for me. Very happy now. 🙂
-Andy
