Programmatically trigger infoWindow for KML layer
2813
07-17-2012 09:15 AM
ThomasLowry
I have a map that I am creating as follows:
var map;
var kmlLayers;
var initExtent = new esri.geometry.Extent({ "xmin": -126.95, "ymin": 21.08, "xmax": -60.24, "ymax": 49.86, "spatialReference": { "wkid": 4326} });
var popup = new esri.dijit.Popup(null, dojo.create("div"));
map = new esri.Map("map", { extent: esri.geometry.geographicToWebMercator(initExtent), "infoWindow": popup });
dojo.place(popup.domNode, map.root);
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
map.addLayer(basemap);
var kmlTownshipUrl = 'http://myServer.net/KML/myKML.kml';
var newKMLLayer = new kmlLayer(kmlTownshipUrl);
newKMLLayer.addLayerToMap(map);
kmlLayers.push(newKMLLayer);
The layer loads just fine, and when I click on it, I get the infoWindow with the approriate name and description fields from the <Placemark> in the KML. I then use my kmlLayers array to call the .hide() and .show() methods when a user checks/unchecks a box, and all works just fine.
What I want to do is programmatically show the infoWindow as well, but as yet have had no success. In order to get the infoWindow to show properly, I have to actually click on it. Has anyone encountered this, and have a solution? Maybe I need to manage the infoWindow data independently of the KML? Any ideas would be helpful. Thanks.
derekswingley1
Use popup.show(). You'll probably also want to use popup.setFeatures() to specify what is displayed in your popup when you show it.
