Proxy page for editing
2122
5
07-17-2012 02:51 AM
davidmaddison
Hi i have downloaded one of the sample ESRI editing examples and added my own maps(rest end points) and they are diplaying as they should. I have downloaded the proxy.ashx and proxy.config. I have set my html page to point at the proxy and config as below. My proxy pages are in C:\Inetpub\wwwroot\proxy i have done as advised in another thread and created the proxy folder to an application.
esri.config.defaults.io.proxyUrl = "http://myserver/proxy/proxy.ashx";
<serverUrl url="http://myserver/arcgis/rest/services/"
matchAll="false"></serverUrl>
i have tried IP address and name both dont work.
when i run application and try to edit with firebug on i get following error
"Unable to load http://myserver/proxy/proxy.ashx?http://myserver/ArcGIS/rest/services/Point/FeatureServer/0/applyEdi... status:500"
so in my browser on the server that hosts arcserver i try to test proxy page with
http://localhost/proxy/proxy.ashx?http://myserver/ArcGIS/rest/services/Point/FeatureServer/0
i get this
Server Error in '/proxy' Application.
Compilation Error
Description: An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately.
Compiler Error Message: CS0234: The type or namespace name 'Generic' does not exist in the class or namespace 'System.Collections' (are you missing an assembly reference?)
Source Error:
using System.IO;
using System.Web;
using System.Collections.Generic;
using System.Collections;
using System.Text;
i have researched System.Collections.Generic and i just cant find what is wrong this was in the downloaded file from esri so i have tried with it removed and does not work.
Has anyone had this error i have looked on forum and people have had problems with proxy page set up but not the same problem as mine any help would be greatfull.
davidmaddison
for info
this is now working thanks to ESRI consultant  it was a setting in iis
i ran  aspnet_regiis -i      This will register ASP.NET 2.0 as the default version with IIS.
then restarted iis
all working
derekswingley1
Are you able to make an edit via the REST API directly?
These issues are not easy to troubleshoot via the user forum. If you're able, I recommend opening a ticket with support.
davidmaddison
Hi how do i open a ticket with support?
davidmaddison
I should have asked how do i  make an edit via the REST API directly?
What i have done is create an editing  application in arcgis server and it worked using the same data(end points) so i knoe it was set up correctly.
But i work with javascript and dojo so i would like to set up web editing with proxy page.
davidmaddison
for info
then restarted iis
all working
HemingZhu
for info
then restarted iis
all working
In the development stage, I usually put prox page in my application folder(like same folder as index.htm etc). It is much easier to debug and role out proxy related issues...
