Configure Custom Info Window
1546
5
07-16-2012 05:25 AM
CraigMcDade
I'm fairly new to the JavaScript API and am trying to create a test map using the Custom Info Window code example that is found here:
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/widget_extendi...
I'd like to switch out the example tree layers for a County Parks service that I created, but am having trouble configuring it correctly. I assume that my trouble is with the InfoWindow module itself.
Any help would be great.
Thanks!
derekswingley1
What have you tried? Do you have the sample using the Tree service running locally? Please post code showing what you're trying to do.
CraigMcDade
Attached is what I'm running locally. My goal is to have an info window popup when I click on a parks feature that shows the Parks name and a link to the County website.
derekswingley1
Thanks. Have you tried incorporating the code from the sample you referenced in your first post? Give it a shot and post back here if/when you run into specific errors/issues.
CraigMcDade
Yes I have, like I said I'm new so I'm 100% confident the issue is on my end. I guess my real trouble is very basic issues I'm sure: where to insert the code and how to edit the info window to reference my parks data.
Do I need to save the js file and css file locally to edit what is referenced in the code?
VenkataSrikanthDasari
Steps to work custom info window for the Trees Map service locally
1.Paste the myModules folder in the C:\inetpub\wwwroot folder
2.Add the package similar to the below code.
var djConfig = {
            parseOnLoad: false,
            packages: [{
                "name": "myModules",
                "location": "http://localhost/(if folderexists/)myModules"
3.That's it.It will work enjoy..
