Measure widget display lenght in Map
3674
5
06-29-2012 01:33 AM
JanJeske
Hey I want to display the lenght from each squence of the measure in the map.
thats works all fine but when I display the first measure of area in the map i got only wrong values displayed.
That is my code i insertet in measurement.js ....
        var _17;
 if(this._map.snappingManager)
  _17=this._map.snappingManager._snappingPoint;
 var _18=_17||evt.mapPoint;
 var xmuss = _18.x - ((_18.x - this.inputPoints[0].x)/2);
 var ymuss = _18.y - ((_18.y - this.inputPoints[0].y)/2);
 var winkelmuss = (Math.atan2((this.inputPoints[0].y - _18.y), (this.inputPoints[0].x - _18.x))*180)/Math.PI;
 var pt = new esri.geometry.Point(xmuss, ymuss, this._map.spatialReference);
 var textSymbol = new esri.symbol.TextSymbol();
 textSymbol.setColor(new dojo.Color([0,0,0])).setFont(new esri.symbol.Font("12pt").setWeight(esri.symbol.Font.WEIGHT_BOLD));
 var gemessen = this._geodesicDistance(this.inputPoints[0],_18)*1609.34;
 textSymbol.text = dojo.number.format(gemessen.toFixed(1), {pattern: this.numberPattern}) + "m";
 if(winkelmuss < 0 && winkelmuss > -90)
  winkelmuss = winkelmuss*-1;
  textSymbol.yoffset = -10;
         textSymbol.xoffset = -10;
 }else if(winkelmuss <= -90)
  winkelmuss = (winkelmuss +180)*-1;
  textSymbol.yoffset = 10;
 textSymbol.xoffset = 10;
 }else if(winkelmuss > 0 && winkelmuss < 90)
 }else if(winkelmuss >= 90)
  winkelmuss = (winkelmuss - 180)*-1;
 textSymbol.angle = winkelmuss;
 this.textGraphic=new esri.Graphic();
 this.textGraphic.setSymbol(textSymbol);
 this.textGraphic.setGeometry(pt);
 this._map.graphics.add(this.textGraphic);
 this.measureGraphics.push(this.textGraphic);
Hope anyone can help me
ReneRubalcava
Esri Frequent Contributor
Where exactly are you adding this?
The measurement.js tool has a field called result.
So you can grab measurement.result.toFixed(2) and apply it to the tooltip or some other feature.
I actually just use jQuery to grab the results and display them in a "history list". After some trial and error, it was just the simplest route.
If you wanted to modify the measurement.js, you may just want to use dojo.extend.
JanJeske
Thanks for the tip with dojo extent i will try it 🙂
I added the code to the _measureAreaMouseClickHandler function in the measurement.js of the jsapi.
Instead of the area i want to have the length of each path. Like this.
[ATTACH=CONFIG]15689[/ATTACH]
I fixed this but my Problem now ist that when i print with the print task there is no more text rotation and some text graphics are gone
JanJeske
I added the code to the _measureAreaDblClickHandler function in the measurement.js of the jsapi.
and
 //Bema�?ung Area hinzugefügt 28.06.2012
   var xmuss = mapPoint.x - ((mapPoint.x - this.inputPoints[this.inputPoints.length-2].x)/2);
   var ymuss = mapPoint.y - ((mapPoint.y - this.inputPoints[this.inputPoints.length-2].y)/2);
   var winkelmuss = (Math.atan2((this.inputPoints[this.inputPoints.length-2].y - mapPoint.y), (this.inputPoints[this.inputPoints.length-2].x - mapPoint.x))*180)/Math.PI;
  // alert(this._geodesicDistance(this.inputPoints[this.inputPoints.length-2],mapPoint));
  // alert(this._geodesicDistance(this.inputPoints[this.inputPoints.length-2],mapPoint)*0.0150605384943241495948941483426);
   var gemessen = this._geodesicDistance(this.inputPoints[this.inputPoints.length-2],mapPoint)*1609.34;
   //textSymbol.text = gemessen.toFixed(1) + "m";
to the _measureAreaMouseClickHandler.
[ATTACH=CONFIG]15690[/ATTACH]
IgorKaruza
Hi!
Is it possible to to achieve the same functionality as in Silverlight API - show measured length while dragging mouse?
Example: Silverligth API - Utility Actions - Polygon Measure
http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#UtilityActions
Br!
Igor
IgorKaruza
