Topology Toolbar Greyed Out
12330
6
06-28-2012 03:16 PM
JazzmineAllen
when I try to use the topology toolbar in ArcMap 10.0 everything is greyed out. I have an ArcInfo license. Should I not be able to use topology?...
-Kalila21
JonathanQuinn
Esri Notable Contributor
Have you added the topology to the Table of Contents?  Did you then go into an edit session?
JazzmineAllen
No, how do you do that?
JonathanQuinn
Go to Add Data, navigate to the feature dataset that contains your topology and then add it to the map.  You can add all layers that are included in the topology if you want.  Then, go into an edit session and the topology toolbar will be active.
ToddLusk
That's not necessary if you're just using "map topology" is it?  I'm experiencing the same symptoms while trying to do it just using map toplogy.  I'm using an ArcInfo license (v10).
ToddLusk
I figured out my problem.  My data frame was in a different projection than my data.
AlecArditti
you need to be in editing mode
