Selecting Nested Polygons using ArcPy
2955
06-21-2012 08:08 AM
AndrewBrown1
First, is there a way to select nested polygons that are completely surrounded by a larger polygon? For example, I'm working with polygons that represent roofs of buildings, and in some cases, there are multiple polygons for a roof, especially when there is a taller  structure in the center of the roof, surrounded by a lower roof area.
Second, would it be possible to automate selection of these nested polygons and tie them to their larger, parent polygon, that completely surrounds them?
I need to combine multiple roof polygons to form one "building" polygon.
Andrew
JeffBarrette
I'm not sure how to find individual, contained features but have you considered using Dissolve for your second question?
Jeff
SolomonPulapkura
You could do this with a Python script.
Very roughly the script would
  1. Loop thru the feature class
  2. At every iteration do a select by location
  3. If something found, perform a dissolve and move on
Of course this is very general logic. Writing the script and making it do exactly what you want is a different matter.
