Spatial Select Data That is Not In Map Service
1109
06-21-2012 07:28 AM
chuckfrank
Hi All,
I am going to be working with point data that is sensitive and cannot be in a published map service, not even with tokens.  I want to do a spatial selection on the points to select the points within a polygon and return attribute information only.  First, is it possible to do a spatial selection against data that is not published as a map service?  I could choose to store the data in any of these formats that might work -(feature class, could be in file gdb, sde, layer in mxd, or even flat sql table).  Second, is there any example of this?
I looked at this tutorial (http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#/GP_service_ex...)  and at #2 "Geoprocessing Service with Source Map Document" it seems to indicate that a geoprocessing service can access datasets on a disk.
My fallback idea is to run a straight sql query on the data and loop through each coordinate to check if it's inside or outside a polygon, but that will only be if I can't find a better way.
Chuck
HemingZhu
Hi All,
Chuck
Runing a GP service without a source .mxd is a pretty good choice. You could be able to choose the feature class directly throught .sde file....
chuckfrank
Do you know the syntax to connect to the SDE database?  I've been using model builder to build geoprocessing services.  I have a clip function to clip an SDE layer, but when I try to publish and test the tool I get a "000732 - dataset does not exist error".  It's trying to find something that looks like this "Database Connections\database.sde\database.DBO.SurfaceWater\database.DBO.sites" but it can't because that's back on the server.  In .NET I'd use a connection string, but I'm hoping to do this in model builder.  Is it possible?
