point and line, attribute
2721
06-20-2012 11:07 AM
JinMa
I have a point feature class and a line feature class; there is no common field between these two feature classes, but I need to extract points that on the line features and keep attributes from both of the feature classes.  Any idea?  Thanks so much.
MathewCoyle
Honored Contributor
If they are directly on the line I would use Intersect. An intersect with a large XY tolerance/resolution environment setting should work as well if they are a little off. Never tested that though.
