Why these two rasters can???t be summed up?
5197
15
06-06-2012 10:53 AM
JamalNUMAN
Legendary Contributor
I???m wondering why the two raster shown in the screenshot below cannot be summed up?
What might be the reason?
[ATTACH=CONFIG]14987[/ATTACH]
Thank you for the help,
Best
Jamal
Jamal Numan
EricRice
Jamal,
Please send a screenshot of 'B' layer properties so I can see the extent values.  Please do the same for Elevation.  What happens if you add Elevation to a blank map, then add B to it?  Does B overlay Elevation?  If layer B has the same extent values as layer A that you uploaded to this forum, that would explain the issue.  You can't add two rasters together if they don't line up with one another.
Eric
DanPatterson_Retired
invalid link error
EricRice
Jamal,
What is happening when you click OK on the tool?  Adding two rasters together is basic functionality and is working correctly from my tests.  I just added a floating point raster to an integer raster just like you're attempting to do.  Your syntax is correct, so you need to elaborate on what's going on.
Eric
JamalNUMAN
invalid link error
Thanks Dan. but why it is invalid?
Jamal Numan
Jamal when I click on the link in your initial thread, that is error message I got.  Usually you have images in your threads but not this time.
EricRice
Dan,
The link is working for me for some reason...That is how I knew his syntax was correct.
Eric
JamalNUMAN
Sorry about that.
I�??m attaching the screenshot to this post. Many thanks for the help.
[ATTACH=CONFIG]14996[/ATTACH]
I couldn't attach both rasters as the size of one of them is more than 2MB. however, the link below might work:
http://www.mediafire.com/?pk6tp1n5zomd3ho
Best
Jamal
Jamal Numan
JamalNUMAN
Dan,
Eric
then could you guess why it is not working Eric? I've attached the two raster in my previous post.
thanks
jamal
Jamal Numan
EricRice
First, you have to tell me what you mean by "not working".  Is there an error?  Is the output wrong?  Have you tried running the Plus tool instead?
Eric
JamalNUMAN
Eric
Many thanks Eric for the prompt answers.
please, have a look on the sort of errors i got on the screenshots below
[ATTACH=CONFIG]15001[/ATTACH], [ATTACH=CONFIG]15002[/ATTACH]
best
Jamal
Jamal Numan
