Can someone please let me know know as to why when i click on my feature points , the info window is not showing up: <html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
<meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" />
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>Editable FeatureLayer in Selection Only Mode with Attribute Inspector</title>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/claro/claro.css">
<style>
html, body {
height: 98%; width: 98%;
padding: 0;
overflow:hidden;
#mapDiv{
padding:0;
border: solid 2px #705B35;
.roundedCorners {
-moz-border-radius: 4px;
border-radius: 4px;
#detailPane{
height:20px;
color:#570026;
font-size:12pt;
font-weight:600;
overflow:hidden;
.dj_ie .infowindow .window .top .right .user .content { position: relative; }
.dj_ie .simpleInfoWindow .content {position: relative;}
.esriAttributeInspector {height:100px;}
.esriAttributeInspector .atiLayerName {display:none;}
.saveButton {
padding-left:45px;
margin:0px;width:16px; height:16px;
</style>
<script type="text/javascript"> var dojoConfig = { parseOnLoad: true };</script>
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script>
<script type="text/javascript" language="Javascript">
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("esri.dijit.AttributeInspector-all");
var map;
var updateFeature;
function init() {
//This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to
//replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
//for details on setting up a proxy page.
esri.config.defaults.io.proxyUrl = "proxy.ashx";
esri.config.defaults.io.alwaysUseProxy = true;
var startExtent = new esri.geometry.Extent({
"xmin": -10591408.5633053,
"ymin": 3383311.8650482,
"xmax": -10541870.717486,
"ymax": 3428122.96783653,
"spatialReference": {
"wkid": 3857
map = new esri.Map("mapDiv", {
extent: startExtent
dojo.connect(map, "onLoad", function () {
//resize the map when the browser resizes
dojo.connect(dijit.byId('mapDiv'), 'resize', map, map.resize);
dojo.connect(map, "onLayersAddResult", initSelectToolbar);
var tiledLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer");
map.addLayer(tiledLayer);
var petroFieldsMSL = new esri.layers.ArcGISDynamicMapServiceLayer("http://test.com/ArcGIS/rest/services/Houston/Test/MapServer");
petroFieldsMSL.setDisableClientCaching(true);
map.addLayer(petroFieldsMSL);
var petroFieldsFL = new esri.layers.FeatureLayer("http://test.com/ArcGIS/rest/services/Houston/Test/FeatureServer/0", {
mode: esri.layers.FeatureLayer.MODE_SELECTION,
outFields: ["APP_ID","OBJECTID","VACANT"]
var selectionSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NULL, new esri.symbol.SimpleLineSymbol("dashdot", new dojo.Color("yellow"), 2), null);
petroFieldsFL.setSelectionSymbol(selectionSymbol);
dojo.connect(petroFieldsFL, "onEditsComplete", function () {
petroFieldsMSL.refresh();
map.addLayers([petroFieldsFL]);
function initSelectToolbar(results) {
var petroFieldsFL = results[0].layer;
var selectQuery = new esri.tasks.Query();
dojo.connect(map, "onClick", function (evt) {
selectQuery.geometry = evt.mapPoint;
petroFieldsFL.selectFeatures(selectQuery, esri.layers.FeatureLayer.SELECTION_NEW, function (features) {
if (features.length > 0) {
//store the current feature
updateFeature = features[0];
map.infoWindow.setTitle(features[0].getLayer().name);
map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
} else {
map.infoWindow.hide();
dojo.connect(map.infoWindow, "onHide", function () {
petroFieldsFL.clearSelection();
var layerInfos = [{ 'featureLayer': petroFieldsFL,
'showAttachments': true,
'isEditable': true,
'fieldInfos': [
{ 'fieldName': 'APP_ID', 'isEditable': true, 'tooltip': 'APP_ID', 'label': 'APP_ID:' },
{ 'fieldName': 'Vacant', 'isEditable': true, 'tooltip': 'Vacant', 'label': 'Vacant:' },
var attInspector = new esri.dijit.AttributeInspector({
layerInfos: layerInfos
dojo.create("div")
//add a save button next to the delete button
var saveButton = new dijit.form.Button({ label: "Save", "class": "saveButton" });
dojo.place(saveButton.domNode, attInspector.deleteBtn.domNode, "after");
dojo.connect(saveButton, "onClick", function () {
updateFeature.getLayer().applyEdits(null, [updateFeature], null);
dojo.connect(attInspector, "onAttributeChange", function (feature, fieldName, newFieldValue) {
//store the updates to apply when the save button is clicked
updateFeature.attributes[fieldName] = newFieldValue;
dojo.connect(attInspector, "onNext", function (feature) {
updateFeature = feature;
console.log("Next " + updateFeature.attributes.objectid);
dojo.connect(attInspector, "onDelete", function (feature) {
feature.getLayer().applyEdits(null, null, [feature]);
map.infoWindow.setContent(attInspector.domNode);
map.infoWindow.resize(325, 210);
dojo.addOnLoad(init);
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;">
<div id="detailPane" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'">
Houston App
</div>
<div data-dojo-type="dijit.layout.ContentPane" class="roundedCorners" data-dojo-props="region:'center'" id="mapDiv"></div>
</div>
</body>
</html>
