Hi all,I need to increase the tolerance of my map points. Before I use icons and there is no problem with event control, but now i need to use text. I tried solutions like http://forums.esri.com/Thread.asp?c=158&f=2396&t=261892 but i think this is not useful for me because i don't use rest services. I show my code
//call method
var geo = new esri.geometry.Point(xPos,yPos,new esri.SpatialReference({ wkid: 25830 }));
var ip = new esri.Graphic(geo, null);
var attr = {"xPos":xPos,"yPos":yPos,"id":id,"tactica":tactica,"estado":estado,"areaOp":areaOp,"fecha":fecha,"tipo":"incidente"};
ip.setAttributes(attr);
myInfoWindowXY(ip,icon);
function myInfoWindowXY(elemento,icono){
try{
var imageSymbol = new Image();
imageSymbol.setAttribute('width', '16px');
imageSymbol.setAttribute('height', '16px');
imageSymbol.src = icono;
//Seleccionamos, en funcion del tipo de punto, la capa sobre la que vamos a trabajar
//si la capa no existe, la creamos
if(elemento.attributes.tipo == "incidente"){
if (gvdiDefaultMap.getLayer("IncidentPointsGraphicsLayer") == undefined){
var incidentsLayer = new esri.layers.GraphicsLayer({id:"IncidentPointsGraphicsLayer"});
gvdiDefaultMap.addLayer(incidentsLayer);
gvdiCurrentGraphicsLayer = gvdiDefaultMap.getLayer("IncidentPointsGraphicsLayer");
}else if (elemento.attributes.tipo == "llamadaSimple"){
if (gvdiDefaultMap.getLayer("AlertPointsGraphicsLayer") == undefined){
var alertsLayer = new esri.layers.GraphicsLayer({id:"AlertPointsGraphicsLayer"});
gvdiDefaultMap.addLayer(alertsLayer);
gvdiCurrentGraphicsLayer = gvdiDefaultMap.getLayer("AlertPointsGraphicsLayer");
}else if (elemento.attributes.tipo == "recurso"){
if (gvdiDefaultMap.getLayer("ResourcesPointsGraphicsLayer") == undefined){
var resourcesLayer = new esri.layers.GraphicsLayer({id:"ResourcesPointsGraphicsLayer"});
gvdiDefaultMap.addLayer(resourcesLayer);
gvdiCurrentGraphicsLayer = gvdiDefaultMap.getLayer("ResourcesPointsGraphicsLayer");
}else if (elemento.attributes.tipo == "llamadaMovil"){
if (gvdiDefaultMap.getLayer("MobilePointsGraphicsLayer") == undefined){
var mobileLayer = new esri.layers.GraphicsLayer({id:"MobilePointsGraphicsLayer"});
gvdiDefaultMap.addLayer(mobileLayer);
gvdiCurrentGraphicsLayer = gvdiDefaultMap.getLayer("MobilePointsGraphicsLayer");
//Añadimos el punto de geolocalizacion con su grafico asociado a la capa pertinente
var displayText = elemento.attributes.tactica;
var font = new esri.symbol.Font("7pt",esri.symbol.Font.STYLE_NORMAL, esri.symbol.Font.VARIANT_NORMAL,esri.symbol.Font.WEIGHT_BOLD,"Helvetica");
var textSymbol;
textSymbol = new esri.symbol.TextSymbol(displayText,font,new dojo.Color("#FE2E2E"));
gvdiCurrentGraphicsLayer.add(elemento.setSymbol(textSymbol));
//gvdiCurrentGraphicsLayer.add(elemento.setSymbol(esri.symbol.PictureMarkerSymbol(icono,imageSymbol.width,imageSymbol.height)));
//Generamos los eventos correspondientes a los clics de raton
dojo.connect(gvdiCurrentGraphicsLayer, "onMouseDown", onMouseDownFunction);
//Generamos el evento correspondiente a un doble clic del raton
dojo.connect(gvdiCurrentGraphicsLayer, "onDblClick", onDblClickFunction);
//Generamos el evento correspondiente a situar el raton sobre un punto.
//Se muestra la cabecera de infoWindow solo mientras el raton este situado sobre este
dojo.connect(gvdiCurrentGraphicsLayer, "onMouseMove", onMouseMoveFunction);
//Generamos el evento correspondiente a dejar de situar el raton sobre un punto.
//Desaparece la cabecera de infoWindow
dojo.connect(gvdiCurrentGraphicsLayer, "onMouseOut", function() {
if(gvdiDefaultMap.infoWindow.getMouseOver() && !gvdiDefaultMap.infoWindow.getMouseClick()){
gvdiDefaultMap.infoWindow.hide();
gvdiDefaultMap.infoWindow.mostrarReducido();
isFirst=0;
isInfoWindowShowing=0;
}catch(error){
mostrarError("myInfoWindowXY: "+error);
function onMouseDownFunction(evt) {
desactivarToolbar(drawToolbar);
desactivarToolbar(navToolbar);
var g = evt.graphic;
/* Not working
//INCREASE TOLERENCE
//var centerPoint = new esri.geometry.Point(evt.mapPoint.x, evt.mapPoint.y, evt.mapPoint.spatialReference);
var mapWidth = gvdiDefaultMap.extent.getWidth();
//Divide width in map units by width in pixels
var pixelWidth = mapWidth / gvdiDefaultMap.width;
//Calculate a 10 pixel envelope width (5 pixel tolerance on each side)
var tolerance = 100 * pixelWidth;
var query = new esri.tasks.Query();
//Build tolerance envelope and set it as the query geometry
var queryExtent = new esri.geometry.Extent(1, 1, tolerance, tolerance, evt.mapPoint.spatialReference);
query.geometry = queryExtent.centerAt(g);
gvdiDefaultMap.infoWindow.setMouseOver(false);
gvdiDefaultMap.infoWindow.setMouseClick(true);
if(isFirst==0)
if(dojo.mouseButtons.isLeft(evt))
if(g.attributes != undefined)
//Generamos el evento correspondiente a un solo clic del boton izquierdo
gvdiDefaultMap.infoWindow.setContent(getInfoWindowContent(g));
gvdiDefaultMap.infoWindow.mostrarExtendido();
gvdiDefaultMap.infoWindow.show(evt.screenPoint,gvdiDefaultMap.getInfoWindowAnchor(evt.screenPoint));
}else if (dojo.mouseButtons.isRight(evt)){
isFirst=1;
Please, help me, im new in esri and dojo and im a little bit lost in this new world!!Thanks a lot!!!
