Asynchronous query calls
2295
05-28-2012 11:04 PM
AndrewLeane
Hi all,
I'm still a newbie with the Javascript API, but my issue seems very similar to one solved on the Flex API forum. I am running multiple queries, and I need to know which layerId the resulting featuresets come from. As the results are asynchronous, I'm not sure which featureset comes from which layer.
The solution on the Flex forum was:
Add the reference to your layer when you do the query like:  queryTask.execute(query, new AsyncResponder(onResult, onFault, myLayerID));  Then define your result handler like :  function onResult(featureSet:FeatureSet, myLayerID:Number):void { ... }
is there a way to do a similar thing in javascript by creating a new AsyncResponder?
Thanks very much
Andrew
nicogis
YohanBienvenue
Hi all,
Thanks very much
Andrew
If the API doesn't provide it to you, I guess you could manually pass the layerId to your callback yourself.
Maybe something like this could work:
function callback(featureset, layerId){
var _this = this;
var query = new esri.tasks.Query();
query.where = "STATE_NAME = 'Washington'";
query.outSpatialReference = {wkid:102100};
query.returnGeometry = true;
query.outFields = ["CITY_NAME"];
queryTask.execute(query, function(featureset){ _this.callback.call(_this, featureset, 12); });
queryTask.execute(query, function(featureset){ _this.callback.call(_this, featureset, 14); });
etc
nicogis
AndrewLeane
Thanks Yohan and Domenico, I used the dojo.deferredList - it's a nice neat way to keep track of the order of the queries. I'll have to remember to check all the samples, not just the API.
Thanks again.
